Cutaway vm28
- Maxbou92
Re: Cutaway vm28
29 Jul 2026 07:44
What are you thinking about air corrector?! I know that they are essential for pods. But should I try without them and if the cruise is better, maybe they’re small a bit for my 750?
Kz750e 1980
- zed1015
Re: Cutaway vm28
29 Jul 2026 08:11Yes! Try them without.What are you thinking about air corrector?! I know that they are essential for pods. But should I try without them and if the cruise is better, maybe they’re small a bit for my 750?
They are easy and quick to remove.
The whole point of them is to richen the off idle and cure the hesitation without changing the pilots and needle position which affects the rest of the fueling curve but if you are already rich in just that area for whatever reason then removing them should lean it off.
If removing them causes it to lean out too far and the hesitation returns you may have to gradually drill them out until the hesitation clears.
They will need enlarging in 0.05mm to 0.1mm increments.
- Maxbou92
Re: Cutaway vm28
29 Jul 2026 08:14 - 29 Jul 2026 08:14
Thank you Zed. What are the size of your jet?!
Kz750e 1980
Last edit: 29 Jul 2026 08:14 by Maxbou92.
- zed1015
Re: Cutaway vm28
30 Jul 2026 00:21PM sent..Thank you Zed. What are the size of your jet?!
