Probably more than you ever wanted to know about inline fuel filters
- slmjim+Z1BEBE
28 Mar 2026 06:31 - 28 Mar 2026 06:48
We found these while poking around for a source for another batch of genuine Visu-Filters. Deep, arcane & geeky stuff that make The Lovely Z1BEBE's eyes glaze over, but slmjim thrives on it
Porous Bronze Inline Fuel Filters for Small Engines, Part 1
www.industrialspec.com/about-us/blog/det...-fuel-filters-part-1
How Porous Bronze Filters are Made & How They Work, Part 2
www.industrialspec.com/about-us/blog/det...-fuel-filters-part-2
Porous Bronze FAQ, Sintering & Applications, Part 3
www.industrialspec.com/about-us/blog/det...fuel-filters-part-3/
How to Choose an Inline Filter – Mesh and Particle Size
www.industrialspec.com/about-us/blog/det...sh-and-particle-size
Plastic Fuel Filter Body Materials
www.industrialspec.com/about-us/blog/det...ilter-body-materials
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 28 Mar 2026 06:48 by slmjim+Z1BEBE. Reason: Unexpected formatting. Linux learning curve / operator error.
The following user(s) said Thank You: ThatGPzGuy, TexasKZ, gd4now, Kofla, Wookie58
- H1Vindicator
Re: Probably more than you ever wanted to know about inline fuel filters
28 Mar 2026 07:09 - 28 Mar 2026 07:17
yes. way more. ha ha. if I were to use one. russell fuel filter. cleanable/replaceable sintered bronze. I have no idea how it comports with all of those industrial specs. ha ha.
www.summitracing.com/parts/rus-645120?se...ZEAQYASABEgKUg_D_BwE
copied from the summit racing link: Russell Billet Aluminum Street Fuel Filters. These billet aluminum street fuel filters from Russell are made of billet aluminum for strength and shock resistance. Designed for carbureted engines making less than 300 HP, these bi-directional filters feature a sintered bronze 40-micron element that can be cleaned or replaced. They're available to fit a variety of fuel line sizes.
Last edit: 28 Mar 2026 07:17 by H1Vindicator.
The following user(s) said Thank You: gd4now
- Cra-z1
28 Mar 2026 08:12
Those filters from Summit are probably Emgo filters. Have you tried to stuff two of those filters on a Z1900 using the stock petcock. Pretty tight. So I use a Pingel Petcock along with their 1 in and 2 out filter. Or if you have the stock petcock they do make a 2 lines in and 2 lines out unit. A bit more expensive but gets rid of the headache of trying to stuff filters in a small area
- Kofla
28 Mar 2026 08:35
This is probably more than I ever wanted to know, but you never know when I might need one. Hahaha
1978 Kawasaki KZ1000 LTD
2010 Kawasaki Ninja ZX-14
- ThatGPzGuy
29 Mar 2026 06:09 - 29 Mar 2026 06:09
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Last edit: 29 Mar 2026 06:09 by ThatGPzGuy.
The following user(s) said Thank You: slmjim+Z1BEBE
- slmjim+Z1BEBE
29 Mar 2026 06:41 - 29 Mar 2026 06:41That's exactly why we use the 90 deg. Visu filters on the 1 - 2 feed from Mama Kaw's dual outlet petcock. They tuck in quite nicely. Lots more room in the 3-4 feed.... Have you tried to stuff two of those filters on a Z1900 using the stock petcock. Pretty tight. ...
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 29 Mar 2026 06:41 by slmjim+Z1BEBE.
- asphalt900
29 Mar 2026 08:01
If it matters, my take on such filtration petrol tasks. I strongly prefer exquisite filtering before it even enters the petcock. As mentioned by Cra-Z1, pingle offers a "sock" over the ON/RESERVE inlets to the ball valve of petcock housing. Every manufacture did this via sock or sediment bowl/screen and were completely adequate. The only things that i can see going wrong is if the lever selector puck disintegrated and bits of rubber detached or, wait for it..re-lining the tank with some product to pretty it up. I've seen that Red-Coat emulsify with fuel and zip right thru any Non-Paper filter only to settle in bowl or metering circuitry. Generally not a problem if used frequently but let a machine sit and petrol drains back out of galleys/jets, you leave behind a film of that broken down Tank coating plugging passages and jets. There's your seafood dinner, ha.
- Mally
30 Mar 2026 04:31
In the UK , hadn’t heard of Visu fuel filters , can get them via APE racing on Amazon , thanks for the heads up . Just re lined my z900A4 tank and keen to make sure anything in the tank doesn’t muck up my carbs . Should be ok as re lined but some insurance is helpful .
76 z900A4 UK model
77 RD250D UK model
99 YZF R6 UK model
77 RD250D UK model
99 YZF R6 UK model
30 Mar 2026 07:13
I see "Ape Racing" fuel filters on Amazon, but can't find these in the APE catalog. Also, some companies sell "Ape Racing" fuel filters, when they are clearly china store fronts. Visu-Filters are harder to find, and more expensive.
The real deal Visu-Filter sintered bronze filters are rated for 65-100 micron. Not particularly fine filtering. They are about as good as it gets for a gravity feed system, though. Some companies claim better filtering, but that usually comes at a cost of flow restriction.
The following user(s) said Thank You: Mally
- Mally
30 Mar 2026 08:11
Ah , probably a play on the APE name and Chinese ones . Have saw other ones for aircraft in the EU ( France) , will have a better look at those and forget the Amazon ones .
Thanks for reply .
Thanks for reply .
76 z900A4 UK model
77 RD250D UK model
99 YZF R6 UK model
77 RD250D UK model
99 YZF R6 UK model
30 Mar 2026 19:24
They claim 10 micron filtration and they also sell petcocks.
golanproducts.com/product-category/filters/super-mini-filters/
- Mally
31 Mar 2026 01:15
Can’t find the Golan ones over here in the uk ,
have found K&N USA made ones on eBay uk .
ebay.us/m/C5IxZ6
will run with those I think .
ebay.us/m/C5IxZ6
76 z900A4 UK model
77 RD250D UK model
99 YZF R6 UK model
77 RD250D UK model
99 YZF R6 UK model
