Where to buy high quality float bowl screws? Stainless, nickle, etc ...
- chopper1963
15 Mar 2026 04:19
I'd like to buy a pound or more of new float bowl screws (M4?) in different lengths. I'd like to have them in plain, stainless and nickle plated. Phillips head only.
Anyone know where to get them?
The topic has been locked.
Re: Where to buy high quality float bowl screws? Stainless, nickle, etc ...
15 Mar 2026 04:47
Little Supply House sells zinc plated cross-point screws with a captive lock washer, like OEM, but not quite as good. Z1 also sells the same, but they have a smaller selection.
The following user(s) said Thank You: chopper1963
- asphalt900
15 Mar 2026 04:48
I buy in bulk from KM Carburetor, Kurt is the owner.
15 Mar 2026 17:08
This is the source I use.
www.japanmotonuts.com/screws
- Kelly E
15 Mar 2026 18:52
We use alloyboltz.com all the time. They do kits, small orders and bulk. It's a small storefront in Florida run buy a vet and his wife, nice people and they answer the phone.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
15 Mar 2026 18:56
I've been pleased with the hardware at ACE Hardware. Probably not as cheap as some online places, but I like being able to walk in, grab just what I want, and get on with my life. I also get a free bag of popcorn......
- asphalt900
16 Mar 2026 03:36
A sampling of what i get from KM Carb Chopper and why i buy from him. I suppose it depends on what you're going for, original or "whatever fits" though? Note, especially when it comes to Stainless Steel replacements. Often the threads are "cut" not rolled. The cut, cheap versions, are hard on the casting material of these machines regardless where they are used. Box store generic versions are nowadays usually found in the Bind/Cheesehead versions meaning the heads of screws are too big to fit the clearances of covers. Kurt also supplies me with the impossible to find these days, unmarked head proper bolts. He has them in captured washer or plain versions. He also carries Black Zinc coating, not the cheap Black Oxide that rusts immediately that the Box Hardware stores sell. I restore these Kawasaki's Chopper, not just haphazardly reassemble them with whatever is laying around. No one i hang with would accept that ha. These shown are Clear Zinc coated, he has "some" Yellow Zinc too. Yellow Zinc was mainly used on electrical components and some carb locations
A few pics to help. Clay
The following user(s) said Thank You: sf4t7, kimchella
- slmjim+Z1BEBE
16 Mar 2026 06:48
We've bought Z1 float bowl screws from Fastenal. Indistinguishable from what comes from Mama Kaw.
www.fastenal.com/home#
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
16 Mar 2026 07:04Wow Clay, take the cotton wool off of it and say what you really think I agree for a "restoration" at the level you work to but for everything else - 99.9% of my fasteners are stainless (with anti-seize) but I'd like to think it isn't "haphazardly" reassembled !!A sampling of what i get from KM Carb Chopper and why i buy from him. I suppose it depends on what you're going for, original or "whatever fits" though? Note, especially when it comes to Stainless Steel replacements. Often the threads are "cut" not rolled. The cut, cheap versions, are hard on the casting material of these machines regardless where they are used. Box store generic versions are nowadays usually found in the Bind/Cheesehead versions meaning the heads of screws are too big to fit the clearances of covers. Kurt also supplies me with the impossible to find these days, unmarked head proper bolts. He has them in captured washer or plain versions. He also carries Black Zinc coating, not the cheap Black Oxide that rusts immediately that the Box Hardware stores sell. I restore these Kawasaki's Chopper, not just haphazardly reassemble them with whatever is laying around. No one i hang with would accept that ha. These shown are Clear Zinc coated, he has "some" Yellow Zinc too. Yellow Zinc was mainly used on electrical components and some carb locations
- asphalt900
16 Mar 2026 07:45
Hey Jim i left You a PM to call me, i can fix-you up or send you in the right direction. Wookie, upholstery shed ha. I was just referring to those Chinese rough die cut SS engine screw kits (often allen) touted on ebay. The lowest grade of hardware produced. And Jim, yes, the 3/4 and some
5mm threaded phillips screws are generally acceptable. I have a Fastenal supplier that comes by every month to restock my neighbor across the street. It's the M6 and up where they started selling the Bigger headed (cheesehead) screws, picture shown. These are what you get at the Box stores/Amazon etc. When used for case covers the head is bigger then the casing. Fitment is poor unless you grind down diameter of head or jam them in messing up the case material. You do Top-Notch work Wookie!! Info was for those poor souls that wouldn't have a clue till they bought or brought it home only then to find out.
- kevski
16 Mar 2026 10:44
Spalding fasteners, Spalding, Lincolnshire.
- chopper1963
16 Mar 2026 16:02
This thread is priceless. "LETS FIGHT OVER FLOAT BOWL SCREWS! I DON'T BUILD JUNK BY USING WHAT'S JUST LAYING AROUND! And here's an out of focus photo to prove it."
