Bring a Trailer CBX Nightmare Will Make Us All Appreciate Our Simple KZs
- chopper1963
22 Oct 2024 06:35
I know it's not Kawasaki related but this might make you appreciate our simple to work on KZs even more:
There is currently a Honda CBX on Bringatrailer (of cash).
Look at the photos and the invoices for the work performed AFTER this bike was first purchased on BAT. Incredible! $15,000!
CBX and RZ500 are two of the worst bikes made in the 1980s to work on, and most expensive as well.
If a seller sold me a motorcycle that needed that much work I'm not sure how I would handle it.
- Cra-z1
Re: Bring a Trailer CBX Nightmare Will Make Us All Appreciate Our Simple KZs
22 Oct 2024 07:42
Any bike that is approaching 50 years will need work. I have spent thousands bringing a simple Z1 back from the brink. The CBX is another animal. Having rebuilt a set of CBX carbs for a friend who owns several of them its a bit more of a challenge. Not so much the technical part but replacement parts for that bike. Some of the critical engine parts are no longer available and good luck if you need anything on the body. I passed up a CBX a while back because of the fact you will need to spend some serious cash to get it running again. I did buy his 74 Z1 along with a KZ900 engine. Now these bikes you can get everything either used or aftermarket. Not so much with the CBX
- H1Vindicator
22 Oct 2024 07:53 - 22 Oct 2024 07:54... The CBX is another animal. ...
The Honda crowd is a whole nother animal too. ha ha.
Last edit: 22 Oct 2024 07:54 by H1Vindicator.
- sf4t7
22 Oct 2024 08:25
From what I can tell from the story, the buyer didn't heed the best advice for buying old motorcycles, old cars, or old trucks:
"Ya gotta go look at it first!"
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: SWest, chopper1963, Wookie58
22 Oct 2024 13:42
- Cra-z1
22 Oct 2024 21:11 - 22 Oct 2024 21:14
Sometimes you do come across a bike that looks interesting from a restoration aspect, however in the back of your mind your kinda thinking just walk away, but no you go ahead a pick it up. I have done that with several bikes knowing I will probably lose in the end. But the enjoyment I have gotten when the bike is finished kinda makes up for the loss of a bit of cash. case in point a 2002 GSXR1000 that had a spun rod bearing and other issues. Dealer took it apart for the kid and found the spun bearing and then called him several days later and said we are going out of business so you better come and get your bike. Oh ya it's in pieces in several tubs. Fun project. Everything sat for 10 years until a sucker came into the picture. Picked it up for $700 and spent another 3,000 or so. Sold it ($3,500) because I wanted to keep my license.
Last edit: 22 Oct 2024 21:14 by Cra-z1.
23 Oct 2024 05:13
Honda makes great equipment but I don't think their design engineers ever speak to their maintenance mechanics. I have a Goldwing and it usually takes me two days to replace the air filter.
- slmjim+Z1BEBE
26 Oct 2024 08:11
slmjim was a Field Tech on analog photocopiers a few decades ago. There was a particular machine from a manufacturer that will remain nameless, that was a Tech's nightmare. The popular field lore wisdom was, a certain high-mortality part was somehow suspended in space at the factory, and the rest of the machine was then assembled around it. Feedback from the Field Techs from that nightmare machine resulted in the creation of a Serviceability Task Force that had huge influence during the design & prototype processes of all subsequent machines.
slmjim tinkered with a Honda Valkyrie (horizontally-opposed flat six) not long ago. Two banks of three CV carbs that need to be precisely sync'd in unison (six channels total) after fuel rail O-ring & float needle valve replacement are a sight to behold & a re-assembly challenge not to be undertaken lightly.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- sf4t7
26 Oct 2024 13:58
Reminds me of the "joke" we used to tell each other at the shop - "Another case where an engineer found out his wife was sleeping with a mechanic"
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: Street Fighter LTD, BCScott
