Chipped carburator.Usable?
  • Mando22
  • Mando22's Avatar Topic Author
06 Sep 2024 21:59
#904045
Good evening. I recently bought a 1982 Shaft that does not run. I took the carburetors out earlier today to clean them and replace the gaskets/floats if necessary, and I found that one of the carburetors was chipped. The rest do not seem damaged at first glance. Is this carburetor still usable? Thank you.
  • Warren3200gt
  • Warren3200gt's Avatar
Re: Chipped carburator.Usable?
07 Sep 2024 03:11
#904048
Yes, no real problem with using that.
The following user(s) said Thank You: Mando22
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Sep 2024 12:03
#904068
Is it bent or just broken?
  • Mando22
07 Sep 2024 15:02
#904081
Just broken.
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Sep 2024 20:00
#904091
It might effect running a little. If it were me I'd use metal screen and 20 minute JB Weld to build it up to match the others. I did that on one of the large fins on the head and it's still strong after two years. Worth a try.
