- Thank you received: 281
Slide Biblically Stuck In CV Carb & Will Not Move
- asphalt900
28 Jul 2024 11:15 #902622
by asphalt900
Replied by asphalt900 on topic Slide Biblically Stuck In CV Carb & Will Not Move
Don't get flustered, unless You actually live in Oakland, at that point I can see why, ha. All the forwarded info was merely to HELP, not to dismay you from those critters working again. But, take it as You may, "blown-out" is Perfect for jetting but ya won't know till you fill with fuel if the Tee/Connector tube rubbers are still intact. Rubber goes South and hardens/shrinks and splits. I do this all day, and not just little bikes.
- asphalt900
28 Jul 2024 11:56 #902624
by asphalt900
Here's an example as to what everyone is talking/referring to. Because i always save disgruntled components i replace, take note. The same bits that were pulled from those previous shown CBX 1000 carbs. All hardened/shrunk/brittle, nothing usable. Make sense?? It, around here, is peat, repeat. Soo many carbs soo little time, he.
- Thank you received: 2835
28 Jul 2024 13:30 - 28 Jul 2024 13:37 #902627
by Nessism
Replied by Nessism on topic Slide Biblically Stuck In CV Carb & Will Not Move
The 1982 GPz550 carbs use 4 O-rings on the fuel inlet Tee and also on the (two) fuel transfer tubes (for a total of 12 on these parts alone). These O-rings are exposed to the outside air and UV light and are sure to be hard as a rock. While I do have O-ring kits for Mikuni and Keihin carbs, I don't have them for the TK family of carbs. Well, I may have some, but I haven't verified the proper sizes. Kawasaki still sells most of these parts, though.
BTW, maybe just the photo, but a jet-needle looks to be missing?
Last edit: 28 Jul 2024 13:37 by Nessism.
- Thank you received: 2070
28 Jul 2024 15:46 #902629
by Scirocco
Replied by Scirocco on topic Slide Biblically Stuck In CV Carb & Will Not Move
Nessism, to be correct, not the jet-needle is missing, the needle jet is missing = the brass bleeder part that holding the main jet.
- sf4t7
- Thank you received: 362
28 Jul 2024 17:21 #902637
by sf4t7
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Replied by sf4t7 on topic Slide Biblically Stuck In CV Carb & Will Not Move
Chopper 1963, our advice here is intended to help you, maybe to avoid things others may have run into. My comment on separating was more of a general observation, not meant to be taken personally.
I drained some carbs in the 90's when putting a bike in storage, turns out rubber o rings and seals (including the o rings on the fuel tees between carbs) were crusty and dry. But it was still a good idea because the insides weren't full of old fuel sludge, and cleaned up quicker in the ultrasonic. So you saved yourself some work by draining years ago.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: hardrockminer
