- Thank you received: 159
Is it possible to lower jetnidle with carbs in the bike vm26?
- Rolf1976_KZ900
10 May 2024 13:55 - 10 May 2024 14:08 #898849
by Rolf1976_KZ900
Is it possible to lower jetnidle with carbs in the bike vm26? was created by Rolf1976_KZ900
Just discovered something strange .I have been tuning the mixturescrews last days/weeks and bike runs good ,but also sot the plugs after using choke at startups.Then when riding it harder with high revs it clears off the sot. Today i was going to sync the carbs and dicovered that when pulled off the rubber boot on the sync tubes fuel dribled out.That cant be right?? the fuel level was checked with clear tube and also tested the floatvalves for leaks this winter they dont leak or overflow the bowls even under a little pressure. The carbs was totally rebuildt this winter and all o-rings was replaced and new viton bowl gaskets. The plugs also sotted down back in august/sept when i just have bought the bike So this must be the jetneedle sitting to high. Is it possible to adjust the jet needle when carbs are in the bike?
and i forgot to mention that the bike was standing in a tilted forward angle when i pulled off the synk rubber boots with the engine running .Also discovered that sometimes riding steep downhill i get a little popp bacfire so its getting to much fuel downhill
Last edit: 10 May 2024 14:08 by Rolf1976_KZ900.
- Thank you received: 2385
10 May 2024 14:28 #898852
by Wookie58
Replied by Wookie58 on topic Is it possible to lower jetnidle with carbs in the bike vm26?
The following user(s) said Thank You: Rolf1976_KZ900
- Thank you received: 2761
10 May 2024 14:29 #898853
by SWest
Replied by SWest on topic Is it possible to lower jetnidle with carbs in the bike vm26?
Yes, what is your elevation there?
- Rolf1976_KZ900
10 May 2024 14:35 #898854
by Rolf1976_KZ900
the jets when at idle.
Replied by Rolf1976_KZ900 on topic Is it possible to lower jetnidle with carbs in the bike vm26?
Yes you might be right.I saw a little depress in the plunger rubbers ,but the rubber was soft and i made the spring a little longer so thinking that it would not be a problem when choke is shut. I replaced the O-rings. Im still thinking the jet needle is sitting to high and the vacuum is drawing fuel upSounds like you may need to speak to Zed1015 about his choke plunger refurb service
- Rolf1976_KZ900
10 May 2024 14:37 #898855
by Rolf1976_KZ900
Steve im not sure ,but the place i was at is not high over sea level.Yes, what is your elevation there?
10 May 2024 15:06 #898859
by SWest
What position are the needles set? Pilot jet and main jet sizes?
10 May 2024 15:07 #898860
by SWest
BTW you can expect a little soot when breaking in.
- Rolf1976_KZ900
10 May 2024 15:32 #898861
by Rolf1976_KZ900
- Thank you received: 2850
10 May 2024 17:08 #898865
by Nessism
Replied by Nessism on topic Is it possible to lower jetnidle with carbs in the bike vm26?
As I recall, the sync tubes are on the bottom of the boots. Given that, it's normal for some fuel to collect in the tubes.
The following user(s) said Thank You: sf4t7, SWest, Warren3200gt, Rolf1976_KZ900
- 1997dr650
- Thank you received: 7
10 May 2024 18:47 #898868
by 1997dr650
Replied by 1997dr650 on topic Is it possible to lower jetnidle with carbs in the bike vm26?
Many of the carbs that I do, the pilot jet opening is so small the only thing I have found to clean them with is a single strand from a bicycle brake cable.... some time in ultrasonic also helps
The following user(s) said Thank You: sf4t7, Rolf1976_KZ900
- Thank you received: 1918
11 May 2024 10:51 - 11 May 2024 10:55 #898886
by Mikaw
Replied by Mikaw on topic Is it possible to lower jetnidle with carbs in the bike vm26?
To answer, yes you could change jet needle clip on the bike. The slide shaft will need to be pulled to access the needle. This would truly be a difficult task still on the bike.
As an FYI, those are fuel pilot screws. Meaning not the correct carbs for your A4. Good carbs but just so your aware those are 1977 Kz1000 and newer used on several models.
Last edit: 11 May 2024 10:55 by Mikaw.
- Warren3200gt
- Thank you received: 716
11 May 2024 12:31 - 11 May 2024 12:37 #898891
by Warren3200gt
Replied by Warren3200gt on topic Is it possible to lower jetnidle with carbs in the bike vm26?
Fuel collecting in the sync cap is totally normal and correct.
Fuel is carried to the cylinder in a vaporised form mixed into air. When you stop the engine the intake rubber is still full of fuel vapour ready to be taken into the cylinder as the next cycle charge.
When you stop the engine that vapour condenses on the rubber inlet walls and runs down to the lowest point, the vac sync port, and fills the plug.
If the plug is removed shortly after stopping the engine it will have fuel in it, if not then that fuel will evoporate and the caps will be dry when removed. No amount of messing with the carb settings will change this.
Assuming your plug colour and engine performance is good your fretting over correct and normal operation.
Last edit: 11 May 2024 12:37 by Warren3200gt.
The following user(s) said Thank You: sf4t7, Wookie58, Rolf1976_KZ900
