Lubricant for VM28 carbs
  • zed1015
  • zed1015's Avatar
Re: Lubricant for VM28 carbs
22 May 2024 02:26 - 22 May 2024 02:35
#899505
I'm in the process of rebuilding the VM28's for my 78 z1r and noticed the felt o-rings on either side of the control shaft are all but gone. There isn't a part number but I imagine someone has found a source for replacing them.
Part number VM28/403.
They are the same for all VM four cylinder carb banks.
Buy from the link below or get some felt sheet and a couple of hole punches and make them yourself.
Mikuni VM33 Throttle Shaft Felt Seal VM28/403 Genuine Genuine Mikuni Gaskets & Seals (nichecycle.com)
Last edit: 22 May 2024 02:35 by zed1015.
The following user(s) said Thank You: Vinsky, sf4t7
  • Vinsky
  • Vinsky's Avatar
22 May 2024 06:22
#899511
At the size posted on their website I can't see how they will fit. I think I will try to make them as you suggested.
  • 4.25mm outer diameter
  • 10mm inner diameter
Vinsky
  • zed1015
  • zed1015's Avatar
22 May 2024 06:58 - 22 May 2024 07:00
#899512
The size of 14.25mm outer and 10mm inner is clearly quoted on their site and is correct.
Last edit: 22 May 2024 07:00 by zed1015.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
22 May 2024 10:17 - 22 May 2024 18:18
#899525
...the VM28's for my 78 z1r and noticed the felt o-rings on either side of the control shaft are all but gone.
Where do those felt orings go? I've pulled apart 4-6 sets of the 77-80 Kawasaki VM carbs and never found any felt rings. I don't see them in the Kawasaki diagrams, or the VM29 exploded diagram.
I'm not saying they aren't supposed to be there, I just never knew about then and don't know where they go.
Anyone have photos?
My dad's '74 Z1
'00 ZRX1100
Last edit: 22 May 2024 18:18 by DOHC.
  • zed1015
  • zed1015's Avatar
22 May 2024 10:22 - 22 May 2024 10:36
#899527
Where do those felt orings go? I've pulled apart 4-6 sets of the 77-80 Kawasaki VM carbs and never found any felt rings. I don't see them in the Kawasaki diagrams for the VM29 exploded diagram.
Anyone have photos?
They go on the backplate .
Either side of the brass bushes for the throttle shaft.
There's six of them.
They are not usually highlighted on the carb schematics as they form part of the backplate assembly which if purchased would have come with them already fitted.
Last edit: 22 May 2024 10:36 by zed1015.
  • Vinsky
  • Vinsky's Avatar
22 May 2024 18:43
#899539
The felt o'rings are in the carb mounting frame. 6 required. Looks like a tobacco pipe cleaner is going to to the job.
Vinsky
The following user(s) said Thank You: Nessism, howardhb
  • sf4t7
  • sf4t7's Avatar Topic Author
22 May 2024 20:00
#899545
I've used the felt seals from Nichecycle referenced by Zed1015 and they fit perfectly on the throttle shaft and also in the upper carb bodies for the slide linkages.
Scotty
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • Vinsky
  • Vinsky's Avatar
23 May 2024 06:25
#899565
Call me thrifty but five bucks each plus shipping for the felt o'ring is a bit much.
Where would you use the felt o'rings in "upper carb bodies for the slide linkage"?
Vinsky
  • sf4t7
23 May 2024 16:26 - 23 May 2024 16:27
#899593
Sorry Vinsky, my boo-boo.  I was thinking of the plastic washer that goes next to the spring inside that metal cup on the linkage.  And it was only 4 months ago I had them apart !  Guess we can call that a "senior moment"  haha
Scotty
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 23 May 2024 16:27 by sf4t7.
  • DOHC
  • DOHC's Avatar
23 May 2024 17:29
#899597
JetsRus has then for $2.14 each. Still expensive, but less so...
www.jetsrus.com/individual_parts/002-640_su.html
My dad's '74 Z1
'00 ZRX1100
  • Vinsky
  • Vinsky's Avatar
25 May 2024 09:47 - 25 May 2024 09:49
#899703
Wife had these felt pads to put under nic-nacs so had to experiment.
Contact spray to hold it in place then a bit of WD40 on the punch. Works great.
Vinsky
Last edit: 25 May 2024 09:49 by Vinsky.
