Mikuni vm 29mm smoothbore pilots
  • richard
  • richard's Avatar Topic Author
31 Jul 2023 19:43
#887756
There is mention of late model mikuni 29s recommending 25 pilots for the kz900
seems big ,I've always used 17.5
Can anyone point out the difference between the early and late model
Is it best to use the 17.5  in the late model 29s in my stock kz900 application
  • Nessism
  • Nessism's Avatar
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Mikuni vm 29mm smoothbore pilots
31 Jul 2023 21:13
#887759
That could depend on the slides, air jets, etc.
www.jetsrus.com/carburetor/carb_mikuni_V...oded_view_parts.html
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
01 Aug 2023 09:42
#887777
I think this info, that posted by OP, came from jetting guides from both Z1 ent and Sudco, as both do indicate larger pilot jets. I did a rather quick search for this info but did not find it on the newer Z1 ent site.  In the past I did pull down tet from both sites,  Here they are
z1 enterpirse jetting guide from www.z1enterprises.com/reference/z1-carb-guide.aspx
Below is a reference of jet settings for the 29mm carb on Z1 / KZ engines.  This is a good starting point for a bike with 4-1 exhaust, after market cams (up to 0.410" lift) and high compression pistons (approx 10.5:1).  Each bike setup is different, so actual settings will vary.
We have included the Honda CB750 settings as a reference.  You will notice the similarity of setup - so.... if you can find a set of 29mm carbs off a CB750, they should work on a Z1.  The same is not so true with smoothbores setup for the Suzuki GS range.  The slide cutaway is different (2mm) - yes, you can still buy new slides, but they are expensive.
28mm (VM28SC)  Z1 & early Z1-A
 Main Jet  112.5
 Air Jet  1.0
 Needle Jet  P-8
 Jet Needle  5J9-3 - last number is the clip position where 1 is at the top of the needle (leanest) and 5 is at the bottom (richest)
 Throttle valve (slide)  2.5mm cutaway
 Pilot Jet   20.0
 Air Screw setting  1 1/2 turns out
 28mm (VM28SC) Late Z1-A & all Z1-B
 Main Jet  112.5
 Air Jet  1.0
 Needle Jet  O-8
 Jet Needle  5J9-2 (last number is the clip position)
 Throttle valve (slide)  1.5mm cutaway
 Pilot Jet   17.5
 Air Screw setting  1 1/4 turns out
 26mm (VM26SS) KZ900A4 & A5
 Main Jet  115
 Air Jet  1.0
 Needle Jet  O-6
 Jet Needle  5DL31-3 (last number is the clip position)
 Pilot Jet   17.5
 Air Screw setting  1 3/8 turns out
 29mm smoothbores  Z1 / KZ900 / KZ1000
 Main Jet  120
 Air Jet  0.9
 Needle Jet  O-6
 Jet Needle  5DL31-3
 Pilot Jet   17.5 or 20.0 (or 25 in the later versions)
 29mm smoothbores  CB750
 Main Jet  115
 Air Jet  0.9
 Needle Jet  O-6
 Jet Needle  5DL31-3
 29mm smoothbores  KZ650
 Main Jet  105
 Air Jet  0.9
 Needle Jet  O-4
 Jet Needle  5DL31-3
 Pilot Jet   15
FROM SUDCO
Application Carb
Model Main Jet Air Jet Pilot Jet Jet Needle Jet Float Throttle Valve N100.604 BS30/97 VM22/210 Needle #261 Series Height VM29/15
Honda CB750 (SOHC) -1978 VM29-A2 #115 .9 #17.5 #5DL31-3 0-8 23mm 1.5
Kawasaki KZ650 (77-79) VM29-A7 #120 .9 #25 #5DL31-3 0-6 23mm 1.5
Kawasaki KZ900 (76-77) VM29-A7 #120 .9 #25 #5DL31-3 0-6 23mm 1.5
Kawasaki KZ1000 (77-80) VM29-A7 #120 .9 #25 #5DL31-3 0-6 23mm 1.5
Suzuki GS750 2-Valve (77-79) VM29-A12 #115 .9 #25 #5DL31-3 0-6 23mm 2.0
Suzuki GS1000 2-Valve (78-79) VM29-A12 #115 .9 #25 #5DL31-3 0-6 23mm 2.0
Float Height  All sizes 17mm
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: Scirocco
  • willemZ900
  • willemZ900's Avatar
  • Z1B 4 ever
01 Aug 2023 13:27
#887783
On my Z1B, 1015CC, 29 pumpers i use 115 mains and 17.5 pilots, airs crew 1 turn out.
