Excessive fuel consumption
  • Beaner242
  • Beaner242's Avatar Topic Author
27 Jun 2023 03:52
#886494
Ok guys. 3 years ago my timing chain broke and did some damage. I picked up an 81 motor and put it in. Same setup as before. Open header and pod filters. Used my carbs that I had put the dynojet kit in. I’ve spent the last couple weeks changing clip positions and I needed bigger pilot jets. It’s running better than ever but my fuel mileage is gone. I rode to work yesterday and today which is around 50 miles total and I’m gonna have to get fuel after work. That’s about 25 mpg. No fuel is leaking that I can find. Doesn’t smell like fuel when running. No smoke out exhaust. I’m at a loss on what has happened? Any ideas would be appreciated. Does raising the needle clip affect that? It’s all highway between 65-70 mph.
thanks.
1982 KZ1000K LTD Chopper
  • Warren3200gt
  • Warren3200gt's Avatar
Re: Excessive fuel consumption
27 Jun 2023 04:16
#886495
Raising the needle or raising the needle clip?
Raising the needle is opening the needle jet richening the mixture at higher revs - reducing the mpg.
Raising the needle clip lowers the needle leaning the mixture at higher revs - increasing the the mpg assuming you've not leaned it off so much that you needle more throttle to get the same  power required to pull the higher gears.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
27 Jun 2023 04:35
#886496
What grade of gasoline are you using?
1982 KZ1100-A2 Sleeper 😎
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
27 Jun 2023 04:57
#886497
When I bought a totally stock low mile KZP I was stunned to find it only got 30 mpg. And they have a four gallon tank.
I rejetted and it now gets 45+ mpg.
  • Beaner242
27 Jun 2023 06:10
#886503
I keep getting this
ErrorKunena Internal Error: Please enable Kunena Debug Mode and report problem in the  www.kunena.org  forum.
  • Beaner242
27 Jun 2023 06:25
#886505
Lowered the clip a couple notches so raising the needle. I can’t believe that would double my fuel consumption.
91-93 octane if I can find it.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
27 Jun 2023 06:59
#886512
What carburetors on your engine?
I don't know why, but my spark plugs get a fluffy black carbon buildup on the base ring when I use anything besides Regular 87 E10 pump gasoline.
  • Beaner242
27 Jun 2023 07:06
#886515
BS 36 I believe. Whatever stock is other other than the dynojet kit I put in them
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
27 Jun 2023 08:43
#886528
If able, please post a picture of the spark plugs for member evaluation.
  • zed1015
  • zed1015's Avatar
27 Jun 2023 09:43
#886531
Lifting the needle will increase low and mid range fuel consumption which is where you are spending most time at cruising.
You likely need to drop the needle, put the stock pilot back and richen up the idle mix on the mixture screw instead.
The following user(s) said Thank You: Beaner242
  • Beaner242
27 Jun 2023 09:50
#886532
I am going to lower it when I get home and see where it goes
  • Beaner242
03 Jul 2023 14:13
#886795
Update if anyone is interested. Returned the needle clip in the second from top position. Installed 45 pilot jets. Fuel screws are 3 turns out. Just went for ride to test it. Back up to 45 mpg. So much better.
The following user(s) said Thank You: daveo, BCScott, Warren3200gt
