idle kz900 kerker
  • Fox
  • Fox's Avatar Topic Author
idle kz900 kerker
30 Apr 2023 07:50
#883994
hello,
after a fresh engine rebuid my idle is eratic.
Look like a air leaking but i recheck all but intake manifolds and exhaust are good. No drop if i use "starter fuid " on the carbs...
the bike was working perfectly with a 4in1 kerker comp large baffle, pods , z1 vm28sc at 17.5 - 117.5 .
The bike was working perfectly with a 4in2 exhaust, air box with single k&n air filter, kz900 vm26 at stock 17.5 115 .
So actually i have the stock kz900, 4in1 kerker large baffle, stock ait box with k&n air filter.
i can't have 1000 rpm. The tacho needle go to 1300 after 1 min and if i try to reduce the idle screw to 1000 the engine drop to 500 and die.
Can its be my carb set up? must i go lean or rich ? i'm surpise to go richer because those carb are rich from factury ...
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • Nessism
  • Nessism's Avatar
  • Away
The following user(s) said Thank You: Fox
  • Fox
Re: idle kz900 kerker
30 Apr 2023 10:49
#884001
I just did it. It don't resolve the problem.
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Apr 2023 10:53
#884002
How old are the intake manifolds?
  • Fox
30 Apr 2023 10:55
#884003
Good and sealed. That's was my first search.
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
30 Apr 2023 13:44
#884011
Some spray with break cleaner around the intake manifolds tell you the truth....
  • Nessism
  • Nessism's Avatar
  • Away
30 Apr 2023 14:04
#884012
Spraying junk on the boots is NOT a definitive test.  I'd replace the boots if they are original.
  • hardrockminer
  • hardrockminer's Avatar
30 Apr 2023 14:23
#884014
Have you rebuilt the choke plungers?  If not, you may have a fuel leak through the choke circuit.
  • TexasKZ
  • TexasKZ's Avatar
01 May 2023 05:00
#884042
Clogged pilot circuits can cause those symptoms. Screwing in the idle adjuster far enough will allow the main jet to start flowing, making up for the clogged pilots, but raising the idle too high. Unscrewing the idle adjuster will finally close the butterflies enough that the mains can no longer flow, causing the carbs to try and run on the clogged pilots, resulting in a really low idle speed.
  • Mikaw
  • Mikaw's Avatar
01 May 2023 05:58
#884051
Maybe I’m missing something. What carbs are you using that give you high idle. You state the bike was running good with Z1-28SC & Kz-26SS. If that’s the case can you put one of those racks back on to rule out some rebuild fault.
