What’s the correct pilot jet size for a kz 1000 st
  • Armahammer
  • Armahammer's Avatar Topic Author
17 Apr 2023 10:10 - 17 Apr 2023 10:11
#883340
Hi what’s the correct pilot jet size for 1980 kz 1000 st with k and n filters and 4into 1 pipe ,with race can , it has 28mm mikunis,
Last edit: 17 Apr 2023 10:11 by Armahammer.
  • Mikaw
  • Mikaw's Avatar
Re: What’s the correct pilot jet size for a kz 1000 st
17 Apr 2023 10:19
#883343
Not to sound sarcastic but the right size is the right size, and gives you the best performance. The forum will need more information.
  • pilot jet size
  • main jet size
  • needle jet size
  • jet needle size
  • slide cutout
  • current plug conditions
Way more involved than jet size. A standard rule of thumb with K&N pods is install air corrector Jets, return all Jets to stock size and go up 2 sizes on the mains.
The following user(s) said Thank You: Armahammer
  • Armahammer
17 Apr 2023 10:34
#883346
What is the stock size at the moment it pops and bangs on the overrun and have the air screws turned down to 1 turn out , plugs seem ok at that colour is brown to cream,
  • Nessism
  • Nessism's Avatar
  • Away
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Apr 2023 11:00
#883352
I'd try 17.5 to start.
  • Armahammer
17 Apr 2023 11:07
#883355
I can’t make out the numbers on jets very worn I will try some 17 .5s thanks guys ,
  • Mikaw
  • Mikaw's Avatar
17 Apr 2023 12:58
#883363
Back fire on deceleration is a lean condition. Could be air leak at the carb holders. Plugged passage in the carb. If I remember correctly 15 pilot 102.5 mains. You really need air corrector jets to limit the lean off idle caused by pods.
  • Injected
  • Injected's Avatar
19 Apr 2023 19:13 - 19 Apr 2023 19:15
#883468
The numbers won't be worn, just very tiny. Get yourself a 4X loop to inspect.
Sometimes China jets don't have pronounced numbers like proper OEM Mikuni/Keihin jets (Japanese) so they may even be no-name brands in the carbs installed by a PO.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 19 Apr 2023 19:15 by Injected. Reason: sp
