Problem with Mikuni Carb Body
  • DanMadBoy
  • DanMadBoy's Avatar Topic Author
  • Banned
  • Banned
30 Mar 2023 06:57
#882182
Stripped screw/carb body problem.
That is, the screw is fine, but where it screws into on the carb body is stripped. Any quick fix for this?
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: Problem with Mikuni Carb Body
30 Mar 2023 07:16
#882183
We've seen longer screw/split washer (similar to OEM but longer) with a nut on the exposed end.  Not pretty but works fine.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
  • zed1015
  • zed1015's Avatar
30 Mar 2023 07:34
#882184
Which screw ??
If it's the float bowl or carb top i helicoil them.
Another alternative is to use a longer screw and nut or tap them out to M5..
  • DanMadBoy
  • Banned
  • Banned
30 Mar 2023 07:43 - 30 Mar 2023 07:45
#882185
Which screw ??If it's the float bowl or carb top i helicoil them.Another alternative is to use a longer screw and nut or tap them out to M5..
Where it screws into the carb body. This screw. For example, I can pull it out with my finger. It doesnt tighten so its stripped in the carb body that the screw screws into.
Last edit: 30 Mar 2023 07:45 by DanMadBoy.
  • zed1015
  • zed1015's Avatar
30 Mar 2023 07:48 - 30 Mar 2023 07:48
#882186
Which screw ??
Attachment not found
Ok! It's the float bowl.. So the alternatives are as in my reply listed above.
Maybe the easiest fix for you is simply a longer screw with a nylock nut on the other side.
Last edit: 30 Mar 2023 07:48 by zed1015.
  • DanMadBoy
  • Banned
  • Banned
30 Mar 2023 07:50
#882187
Which screw ??
I was updating the attachment. Its where it screws into the carb body thats stripped. See below. I can pull this screw out with my fingers!!
  • Warren3200gt
  • Warren3200gt's Avatar
30 Mar 2023 08:54 - 30 Mar 2023 09:59
#882189
I've used 4mm Rivnuts in this situation on dozens of carb sets over the years.it pulls into the carb body as far as the lip and the knurled portion grips the carb. A stripped 4mm thread is the perfect size to grip the knurl so don't even need to drill the hole bigger.
Can't pull through, can't spin, you end up steel/steel threads not steel/soft cast ally.
simple and effective.
Simple fix.
Picture for illustration
Z1000J2 somewhat modified!
Last edit: 30 Mar 2023 09:59 by Warren3200gt.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
30 Mar 2023 13:11
#882197
I would try to glue a M4 nut on top of the carb body with JB weld first, it´s non inversive and removeable.
Rivets can crack the zinc carb body easy and can cause more damage and trouble you didn´t want.
  • Warren3200gt
30 Mar 2023 13:23 - 31 Mar 2023 02:08
#882198
I've done dozens of them Scirocco. Never had one crack yet. The metal is quite thick there and has the extra thickness of the external rim. The way to do it is to use a bowl screw with a washer on. Put it up through the striped thread from underneath without the bowl in place. Screw the Rivnuts on with the flange uppermost then slowly wind the screw up which pulls the Rivnuts down into the cab body. Once it's seated is not going anywhere and the screw force is spread over the surface diameter of the lip rather than a few alloy threads.
The trick is knowing what your doing and the skill to do it.
Last edit: 31 Mar 2023 02:08 by Warren3200gt.
  • DanMadBoy
  • Banned
  • Banned
30 Mar 2023 15:44 - 30 Mar 2023 18:25
#882204
Yeah Im not going to do that.
Last edit: 30 Mar 2023 18:25 by DanMadBoy.
  • DanMadBoy
  • Banned
  • Banned
30 Mar 2023 18:25
#882207
All taken care of. I have the bolt and the nylon washer. Had a SS set among my tools etc.
  • slmjim+Z1BEBE
31 Mar 2023 04:55
#882211
Noticed the hex head fastener.  Those are a recipe for stripping threads in soft alloys very easily.  Float bowl screws don't have to be King Kong tight.  If the gasket's not fresh, over-tightening the screws won't help anyway. Suggest a torque screwdriver such as those used in the gunsmith trades.to reduce the likelihood of over-tightening & stripping small hex fasteners in soft metals.
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
