Mikuni Flatslides Bell crank wheel
- DFIGPZ
Re: Mikuni Flatslides Bell crank wheel
28 Mar 2023 13:14PM doesn't work but I can put you in touch by email if you are both in agreementjoe
if you want to ship to Maryland I have had many sets of Mikuni Flatslides apart shoot me a PM if you do not want to tackle yourself
Barry
I am ok with it
1984 750 Turbo
The following user(s) said Thank You: rivman15, Wookie58
- rivman15
11 Apr 2023 04:32Hi Joe - I sent it to your frontiernet email 31/3/2023, I guess that is old news. Have forwarded to your gmailEmail works for me. Thanks.
- DFIGPZ
11 Apr 2023 14:56Email works for me. Thanks.
if you decide to email me put "MIKUNI Flatslide repair " in subject line
Barry
1984 750 Turbo
- rivman15
12 Apr 2023 16:09
I did not realize my very old email was still in there, Holy cow I have been on here along time. New email has been updated. Thank you.
- rivman15
23 Apr 2023 08:01 - 23 Apr 2023 10:06
I am going to take a stab at this. Can you remove just half the carbs off the bar to get to the bell crank or does it have to be completely dis assembled?
Last edit: 23 Apr 2023 10:06 by rivman15.
- rivman15
23 Apr 2023 10:08
Do you have to remove everything off the throttle shaft to split the carbs?
23 Apr 2023 10:15
In my opinion you only have only remove carb# 1+2 to slide out the cank wheel to the LH site of the throttle shaft.
- rivman15
23 Apr 2023 10:20
Taking a quick break. There must be another doll pin I havent seen. I was trying to remove carb #4 first and it appears to be still locked on(loose but not coming off) Throttle bar is still attached I can see it would be easy to replace as soon as I can get that throttle shaft off.
- rivman15
23 Apr 2023 10:35
There has be to something else holding the throttle shaft on. Not sliding out.
23 Apr 2023 10:42
Do as Scirocco says. Remove 1&2. Taking off 3&4 gets you into the return spring and cable bracket.
23 Apr 2023 11:15 - 23 Apr 2023 11:18
I do never understand the people asking here for help and than do the opposit as suggested
What a waste of life time sometimes.....
Last edit: 23 Apr 2023 11:18 by Scirocco.
