Aftermarket carb boots
- DFIGPZ
Re: Aftermarket carb boots
28 Feb 2023 12:57
most aftermarket stuff is garbage compared to OEM
1984 750 Turbo
- Ian_B
01 Mar 2023 00:08
On the "making straps to solidly connect the carbs to the engine"; I had always thought that the reason that the carbs were rubber mounted was to isolate them from engine vibration, which would (might) cause the level in the float bowl to be unstable. The proof of the pudding is clearly in the eating, if those who have installed the straps aren't having any problems.
Ian
Ian
01 Mar 2023 02:09I did wonder about fuel frothing but it seems to be working for peopleOn the "making straps to solidly connect the carbs to the engine"; I had always thought that the reason that the carbs were rubber mounted was to isolate them from engine vibration, which would (might) cause the level in the float bowl to be unstable. The proof of the pudding is clearly in the eating, if those who have installed the straps aren't having any problems.
Ian
- Warren3200gt
01 Mar 2023 04:07
I would be more worried about carb sync if there was that much vibration and cobbled streets are a thing of the past. Although the lack of road maintenance in the UK is doing its best to make cobbled streets a thing of luxury!
The following user(s) said Thank You: Mikaw, Wookie58
