Rejetting Carbs for exhaust change: 2 into 2 to 2 into 1
- ShaneDude
- Banned
25 Aug 2022 17:58
Do you need to rejet on a 77 KZ750 B1 Twin thats going from 2-2 to 2 into 1?
Curious.....
Curious.....
- DoctoRot
Re: Rejetting Carbs for exhaust change: 2 into 2 to 2 into 1
25 Aug 2022 22:11
most likely, however if the restriction is the same, you should not need to.
- kevski
25 Aug 2022 23:36 - 25 Aug 2022 23:39
Unless the exhaust is completely open the answer is generally no, it's when airboxes are changed or when pods are put on that jettings are changed, though that said my own stateside KZ has a 4 into one and I changed the jetting slightly on 26mm pumpers to suit the UK conditions.
Last edit: 25 Aug 2022 23:39 by kevski. Reason: Added more to post.
- ShaneDude
- Banned
26 Aug 2022 06:15thanks for this!most likely, however if the restriction is the same, you should not need to.
