What to use to poke out/clear a Mikuni pilot jet ?
  • Mikaw
  • Mikaw's Avatar
Re: What to use to poke out/clear a Mikuni pilot jet ?
24 Jun 2022 15:31
#869307
If the pilot jet is plugged there’s a great chance the rest of the carb is dirty. Nothing bad can come of a quality rebuild.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
24 Jun 2022 16:23 - 24 Jun 2022 16:27
#869309
I would try to cook the clogged jets in coffee machine descaler or vinegear.
Last edit: 24 Jun 2022 16:27 by Scirocco.
  • Nessism
  • Nessism's Avatar
24 Jun 2022 17:20
#869311
I suggest soaking the jets in carb and choke cleaner spray with a top on it over night. A single carb for two cylinders should have a larger pilot jet. Could be the varnish makes it seem smaller. The wire brush strand is smaller than an E string but isn't very strong.
This is what I do.  Shame on anyone trying to clean a set of carbs if you don't already have some carb spray.
  • JR
  • JR's Avatar Topic Author
25 Jun 2022 15:41 - 25 Jun 2022 17:02
#869347
Update and ending.
Drove the hour over to friends place this morning and to make a long story short he did indeed have fuel delivery issues which were caused by combination of dodgy petcock and sticky float and which were pretty much solved by the time I got there. Carb cleaner sprayed easily through jets and orifaces. No need to remove pilot so did not learn what size.  Bike fired up. Sounded good. Left after an hour he still had valves to adjust and fluids (oil, transmission & primary chain) to change etc.
Reminded me why I did not buy that 2nd hand Triumph 500 back in 79
thanks all
Last edit: 25 Jun 2022 17:02 by JR.
  • 750 R1
  • 750 R1's Avatar
25 Jun 2022 15:46
#869348
HE SAID THE HIGH E STRING IS TOO LARGE.
What are you yelling at ?  We're all trying to help here.   You can get E strings down to .006,which is .1524 mm.
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 Jun 2022 15:55
#869352
Who's yelling?
