The "Unicorn" fuel tap? 1981 KZ1000P
  • wallster
  • wallster's Avatar Topic Author
22 Jun 2022 09:16
#869211
I have a 1981 KZ1000P and the fuel tap needs some love, specifically a rebuild kit. I've searched high and low and I'm unable to find a fuel tap or rebuild kit for this specific fuel tap.
Any other models use the same one?
Thanks,
Wally
No amount of planning will ever replace dumb luck.
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
Re: The "Unicorn" fuel tap? 1981 KZ1000P
22 Jun 2022 10:27
#869214
Go to partzilla and enter your specific info. click on the part you're looking for ant it will take you to a page that lists all the other models that use the same part... right down to the color.
  • TexasKZ
  • TexasKZ's Avatar
22 Jun 2022 16:56
#869226
If yours is a 1981 cop bike, it is  a KZ1000C3, not a KZ1000P and that fuel tap and it’s parts are no longer available from Kawasaki. K&L may still make the rubber parts.
  • wallster
23 Jun 2022 05:49
#869241
I went to that exact site and page. None of the Diaphragm parts are available (ring, spring, valve assembly, etc) these are what I really need to make it work properly.
Thanks!
  • wallster
23 Jun 2022 05:51
#869242
It'll work for now but I'll have to make something else work over the winter. Old bike, one off fuel tap... that's how it goes.
Thanks!
  • ghostdive
  • ghostdive's Avatar
23 Jun 2022 06:16
#869243
The parts aren't available on that site, but if you put the part numbers into a search engine you might have some luck.
For example,  this came up when I searched the diaphragm part number. It's worth a shot for whatever else you may need.
2001 ZX-6R
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
23 Jun 2022 06:31 - 23 Jun 2022 06:31
#869245
Last edit: 23 Jun 2022 06:31 by kzstreetfighter71.
  • Nessism
  • Nessism's Avatar
24 Jun 2022 05:25
#869286
Rebuilding fuel taps is very hit or miss.  Mostly miss, unless you can find OEM parts for the rebuild.  Aftermarket kits are notorious for not fitting. Unless OEM bits can be found, I'd skip the rebuild and look for a new tap.  Measure the center to center bolt distance and go hunt eBay.  Most of the time you can find something decent that way.
  • slayer61
  • slayer61's Avatar
24 Jun 2022 07:52
#869289
Cough, cough... Pingel.. cough cough
  • wallster
24 Jun 2022 11:31
#869298
My thoughts exactly... just need an ON-OFF fuel valve that bolts up.
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Jun 2022 13:21 - 24 Jun 2022 13:23
#869303
Doesn't Z1E have them for Suzuki that would fit?
www.z1enterprises.com/search?q=petcock
Last edit: 24 Jun 2022 13:23 by SWest. Reason: add link
