Milling carburetor slslideide as discribed in Clymer manual.
  • LATER
  • LATER's Avatar Topic Author
10 Jan 2022 07:40
#860325
Hey everyone! In my 1977 Clymer service manual, under Performance Modification, they suggest milling 0.30"off the carburetor slide. Im attempting to get a 1978 1000 LTD back on the road. It has a vm26 carbs, without pumpers,and without side mixture screws. Has any of you done this?  any feedback would be apperciated, Thank you
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Milling carburetor slslideide as discribed in Clymer manual.
10 Jan 2022 08:14
#860329
It depends on which slides you have. That mod was to correct off idle performance. I never did it and there's a better mod you can do. What slide do you have? 2.0 or 1.5.? Start there.
kzrider.com/forum/3-carburetor/615950-ai...lation-how-to#849014
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
10 Jan 2022 08:14
#860330
Is there a diagram that shows what part is supposed to be cut?  One of the more subtle adjustments for the VM carbs is the slide cutaway.  They were available in a range of sizes.  The larger the cutaway the leaner the mixture is, with this cutaway mostly impacting the 1/4 to 1/2 throttle range.  See the mikuni tuning manual PDF I've attached (often you have to download it to view it).
In general my recommendation would be that if you are running a stock or nearly stock engine (internals that is), you should set up the carbs exactly as they came from the factory and keep the factory air box.  It should run well that way.
Second, I would not cut parts of the carbs. If you'd like to try slides with a different cutaway, correct parts can be found.
Third, I would not use Clymer manual.  The Kawasaki factory service manuals are really excellent and are relatively easy to find in PDF and print.
My dad's '74 Z1
'00 ZRX1100
The following user(s) said Thank You: Nessism, SWest
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 Jan 2022 08:33 - 10 Jan 2022 08:34
#860333
I had that manual. The one I have now that section was pulled out. The early Z1's had 2.0 slides. They are 1.5 from then on. They also changed the pilot systems. It's important to know which carbs you have then act accordingly. IMO the air corrector jets are the best way on the later carbs.
Last edit: 10 Jan 2022 08:34 by SWest. Reason: sp
  • Injected
  • Injected's Avatar
10 Jan 2022 08:40
#860334
I agree with SWest, I have that manual and the carbs they show getting modified are early 28's. If you have 26's I suggest you do not do that modification, look elsewhere to solve whatever carb issue your having.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
  • LATER
10 Jan 2022 10:57
#860348
Thanks everyone, The story is. I bought this bike for $500 ,7000 miles on it. it has been downed one time, stored indoors for about 8 years.Someone incorrectly mounted extended forks on it. so the cables, switchbox and wires have all been stressed. I slid the forks up, mounted some flat bars on some bar backs which will be fine for now. I put a battery in and drove it around the block. the brakes needed attention, oil was comming out of (I hope) the tach seal. The bike was very weak off idle, It has K&N pods on it. It will be while before I get to the carburetors. Im pretty sure it has the factory jets in it. In the mean time Im collecting all the info, and parts I can. You all have been a great help, Thank you!
  • kevski
  • kevski's Avatar
10 Jan 2022 12:37
#860355
if you have stock jets in it, the pods will be part of the problem, with pods you will probably need air corrector jets which eliminate the off idle stumble, you can get these from Z1015 who is a member on here, he is in the UK though.
  • Mikaw
  • Mikaw's Avatar
10 Jan 2022 12:44
#860356
The pods are causing your off idle issue. If the engine internals are all stock, you have a couple options. Look for a set of 28mm off of an 80 LTD 1000, they have an accelerator pump. Or a set off a 78 Z1R, they are 28mm but no pump. Either or whichever running pods contact Zed1015. He sells air corrector jet that correct the off idle issue.
  • zed1015
  • zed1015's Avatar
10 Jan 2022 12:51 - 10 Jan 2022 12:54
#860357
As Kevski and Mikaw has advised.
All you need is the air corrector jets i provide and a minimal increase in main jetting to cure the weak off idle mixture and correct the overall jetting for pod use..
Just ask any member who has fitted them for their recommendation or use the forum search function for comments on their results.
You can PM me if you decide you want a set and i am happy to provide any help and advice you need.
Last edit: 10 Jan 2022 12:54 by zed1015.
The following user(s) said Thank You: LATER
