1980 KZ750G fuel petcock HELP!
  • tdogm6@yahoo.com
  • tdogm6@yahoo.com's Avatar Topic Author
02 Dec 2021 10:57
#858546
Can anyone tell me about this valve? I need a rebuild kit due to leaking when I turn it on/off. I believe it’s only the rubber bushing (has four holes?) that’s  damaged. It’s on a 1980 KZ750G and it’s a dual outlet.
1980 KZ750G
  • martin_csr
  • martin_csr's Avatar
Re: 1980 KZ750G fuel petcock HELP!
03 Dec 2021 05:43 - 03 Dec 2021 06:01
#858563
Howdy. I tried the diagrams at Partzilla but yours doesn't seem the same & I don't know if your fuel valve is stock or from another model or what. The ALFA markings could indicate that it's an aftermarket petcock from back in the day. ???
www.partzilla.com/catalog/kawasaki/motor...i-kz750-g1/fuel-tank
In case there aren't any repair parts.  Z1Enterprises.com lists a number of fuel valves, but you'd have to figure out which one will fit.
From some other topics the fuel tank bung is probably 22mm w NPT threads (13/16 on a Harley), but you'd have to verify that.
Pingel brand are kind of pricy but should be high quality. cheap chinese on EB are known to fail or break.
Last edit: 03 Dec 2021 06:01 by martin_csr.
  • DoctoRot
  • DoctoRot's Avatar
03 Dec 2021 09:57
#858570
That's not a stock petcock, the reducer is the give-away
  • tdogm6@yahoo.com
06 Jan 2022 16:08
#860120
What did the stock petcock look like?
1980 KZ750G
  • TexasKZ
  • TexasKZ's Avatar
07 Jan 2022 08:46
#860153
If you click the link that martin_csr posted, you will see an exploded view of the factory valve.
