Rejetting carbs after major work
- rokit_armor
20 Aug 2021 18:27
These silly CV carbs are going to be the death of me.
Rebuilt my motor, and now I can't get the dang thing to little more than fire a couple times.
The specs:
KZ1100 A2
75mm bore 10.25:1 wiseco pistons (K1171 kit)
Web 110 cams
MAC 4-in-1 exhaust - with ceramic baffling added
Pods on intake (I know, I know)
BS34s with 137.5 mains, 45 pilots w/pilot screw 3.5 out - this is how it was jetted before the bore/cam work was done and ran just fine like this. I have also moved 300' up in elevation since it last ran, if that makes a difference.
Head has been done with new valves, properly shimmed. Timing is set correctly.
With the cam and high compression pistons, would one tend to need to go richer, or leaner?
I would suspect richer, however the plugs are black, potentially wet.
I rejetted to 125 and 40 pilots, no change.
Restricted airflow in pods, no change.
I forgot to plug the vacuum nubs up once, and it kinda fired up, which confuses me.
Thanks for any advice guys, always appreciate it.
The specs:
KZ1100 A2
Web 110 cams
- rokit_armor
Re: Rejetting carbs after major work
20 Aug 2021 20:57
I decided to take a step back and start troubleshooting from the beginning. Cam timing is good. I have spark on all four plugs (New wires, original coils, I did not use the stock plugs, will this be an issue?) however it is doing a strange thing where it fires about 30 degrees advanced and then again on time, it doesn't do it all the time, I'd say about every 5 or so rotations. Is this an issue?
- Rick H.
21 Aug 2021 04:05
I am not sure what setup you have, but it sounds like your spark advancer could be the problem if your ignition system is similar to a 900/1000. If the weights are sticking timing will be advanced when it shouldn't be. Others will chime in that may have an engine like yours. There are some more detailed threads on this subject, but a defective timing advancer can give you fits.
Rick H.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
- slmjim+Z1BEBE
21 Aug 2021 04:55
Did you check compression? What is the voltage at the coil primaries?
Higher compression requires higher potential (spark energy/voltage) for the spark to cross the plug gap.
For practical purposes, atmosphere is an insulator. High voltage is required to ionize atmosphere at standard sea level pressure enough to become conductive, allowing a spark to cross a gap. The larger the gap, the higher the voltage required to create enough ionization to allow the atmosphere to conduct, resulting in a spark.
When atmosphere is compressed, it's insulating properties increase, requiring more voltage to create a spark than at normal atmospheric pressure. The higher the compression, the more voltage is required to spark across the same gap.
Stock coils are notoriously average, at best. Stock coils that were adequate for stock compression might not be powerful enough to reliably spark the plugs at higher compression.
You might consider installing more powerful coils to go along with the higher compression.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
21 Aug 2021 08:16Thank you for explaining this, I had heard the same thing but never an explanation of why. This is such a great forum.Did you check compression? What is the voltage at the coil primaries?
Good Ridin'
slmjim & Z1BEBE
- rokit_armor
21 Aug 2021 09:47 - 21 Aug 2021 11:01
No eBay APP ID and/or Cert ID defined in Kunena configurationGreat explanation, thank you so much!
I'll double check the advancer, just in case its sticking.
Anyone have a set of green Dyna coils they'd be willing to part with?
So the plan should be as follows-
Upgrade coils
Jet to stock, and jet up until powerband is good?
Edit: Has anyone had good luck with Magna coils? The price point is a bit more reasonable for me.
Upgrade coils
Last edit: 21 Aug 2021 11:01 by rokit_armor.
- DoctoRot
21 Aug 2021 13:20 - 21 Aug 2021 13:27
if the system remains the same and only compression or displacement changes you will typically need to jet leaner. the engine is creating a stronger signal to the carbs by breathing more and faster so it draws too much fuel. if it wants to run without the vacuum plugs in that would suggest that it is very rich.
have you verified you're getting full voltage to coils?
Last edit: 21 Aug 2021 13:27 by DoctoRot.
- rokit_armor
21 Aug 2021 17:56
I checked a few things:
- primary coil ohms at 3 ohms
- Secondary at 12k ohms
- Pickups are at 450 ohms
- rokit_armor
31 Aug 2021 22:02
I have rebuilt the harness, and now show 12.4V at the coils, just under the 12.6v I had at the battery. Rejjetted the carbs back to stock- 37.5 pilot, 120 main, needle on 3rd notch. Ran cleaner through them again just to be sure. Not much change, maybe a bit better. I went ahead and ordered 32.5 pilots and a set of mains 100 through 110. Plugs are sooty and piston looks wet even. Photos for reference. The cat didn't help much either. Terrible shop hand.
- DoctoRot
02 Sep 2021 18:50 - 02 Sep 2021 18:51
Some times cheap pods will block the carb orifices. have you checked to see if they are obstructing the ports? have you tried running it without the filters?
Last edit: 02 Sep 2021 18:51 by DoctoRot.
02 Sep 2021 19:08 - 02 Sep 2021 19:10
Plugs are carbon fouled. Usually a rich condition. As DoctoRot suggests check the pod fit and make sure none of the air port are blocked. You could be fighting a carbon fouled cylinder, piston, valves, etc.etc. Get new plugs. Don’t install them. Start the bike and let it warm up. Shut it off, swap in the new plugs and take the bike for a ride and give it a good ol’ Italian tune up.
Last edit: 02 Sep 2021 19:10 by Mikaw.
- krazee1
02 Sep 2021 19:48 - 02 Sep 2021 19:49
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
Last edit: 02 Sep 2021 19:49 by krazee1.
