Slow drip on all 4 bowls
- BlackEyeCafe
28 Apr 2021 09:16 - 28 Apr 2021 09:25
Checked out the site and could not find an exact answer so i apologize if this has been asked and answered.
As everyone else who asks a carb related question this started after rebuilding and replacing gaskets and jets etc.
The bike runs great but over night or even after a few hours i see fuel slowly dripping from each of the carb bowls.
Think I had set the float heights incorrectly i developed a bench test board and level tool and reset the heights to within specs. I replaced the float plugs with ones from another set of carbs i have and new gaskets.
I put the carbs back on the bike and no leak after a few hours so i let it sit over night and sure enough a slow leak again. Now it's less then before but still present.
Need some suggestions as I'm at me frustration limit.
Red dots represent the location where I see the fuel dripping
leveled front/back side to side
Hose guage method
Rig without carbs
Hose guage method
Rig without carbs
1977 KZ650 C
Jets - Main 115 - Pilot 17.5 - Needles - Position 3 - NGK BR7ES
Last edit: 28 Apr 2021 09:25 by BlackEyeCafe. Reason: Added more information
Re: Slow drip on all 4 bowls
28 Apr 2021 10:09
See photo.
It’s impossible to have a leak at the Black Arrow. If you have a leak at Red Arrow, your missing an O-Ring on the bowl screw. A leak at the Green Arrow points toward float needle and seat not sealing.
28 Apr 2021 10:14 - 28 Apr 2021 19:55
You may have fuel leak at Red Arrows that could run down the sides of the bowls and drip off the Area at the Red and Black Arrows in the first photo.
Last edit: 28 Apr 2021 19:55 by Mikaw.
- TheTrout
28 Apr 2021 10:14
Almost sounds like you forgot the float valve seat on all four carbs.
1978 KZ1000B2
- Zeerx
28 Apr 2021 17:47
This maybe doesn’t apply to your problem but could be something for you (and others that have gas leaks) to think about. I had a nagging leak on a nice set of great running carbs. No matter what I did gas kept coming from the bottom of the bowls. The overflows. After a couple of weeks I finally figured it out. The overflow pipe had corroded where it passes through the bowl. Gas was leaking through the hole in the pipe and exiting the overflow making it look like the bowl had too much gas. A new bowl and the leak was no more. Good luck.
‘99 ZRX1100, ‘05 DRZ400S, ‘78 KZ1000LTD, ‘12 F150 (Ford)
- ckahleer
28 Apr 2021 18:47 - 28 Apr 2021 18:53
Have you left it all set up on your test fixture for a few hours? When a carburetor starts leaking, is the fuel level in the clear tube above the correct level?
Also, cheap aftermarket float valve needles will leak. Use only quality needles.
94 KE100
82 KZ305
85 VF1100c
82 KZ305
85 VF1100c
Last edit: 28 Apr 2021 18:53 by ckahleer.
- BlackEyeCafe
29 Apr 2021 15:38 - 29 Apr 2021 15:47It's possible that there is a slow leak in the crossovers. I didn't replace those seals as they seemed to be fine.
1977 KZ650 C
Last edit: 29 Apr 2021 15:47 by BlackEyeCafe. Reason: Format
- BlackEyeCafe
29 Apr 2021 15:49I did and the the level stayed solid leading me to believe the the float and float needle valves were doing their jobs. Needles were from a reputable source however I am not sure at the moment which brand.Have you left it all set up on your test fixture for a few hours? When a carburetor starts leaking, is the fuel level in the clear tube above the correct level?
1977 KZ650 C
29 Apr 2021 15:50 - 29 Apr 2021 15:52The seals are dryed out but swollen up with the use of fuel penetraion. If not a short pice of shrink tube give you more pressue to seal the fuel connection. This is my personal hack to seal the fuel-T to the carb joint.....
Last edit: 29 Apr 2021 15:52 by Scirocco.
The following user(s) said Thank You: BlackEyeCafe
- BlackEyeCafe
29 Apr 2021 15:50Thank you for the suggestion but the overflows are crystal clearThis maybe doesn’t apply to your problem but could be something for you (and others that have gas leaks) to think about. I had a nagging leak on a nice set of great running carbs. No matter what I did gas kept coming from the bottom of the bowls. The overflows. After a couple of weeks I finally figured it out. The overflow pipe had corroded where it passes through the bowl. Gas was leaking through the hole in the pipe and exiting the overflow making it look like the bowl had too much gas. A new bowl and the leak was no more. Good luck.
1977 KZ650 C
- BlackEyeCafe
29 Apr 2021 15:55Thank you. The seats are in.Almost sounds like you forgot the float valve seat on all four carbs.
1977 KZ650 C
- bluej58
29 Apr 2021 17:35
I clean/polish the seats with brass polish and a spinning Q-tip
They can get pretty filthy
78 KZ1000 A2A
