BS34 750 carb boots - part number confusion
  • ghostdive
  • ghostdive's Avatar Topic Author
27 Mar 2021 10:22
#845601
Last year I bought a set of 1000/1100 boots from Z1E, as they mention that  this set  doesn't work with BS34s - however, checking the parts diagrams, the numbers seem to be the same for Keihin and Mikuni equipped 750s.
Mainly I'm hoping that I can buy these (once back in stock) not only because they have the proper bolt spacing (a pain to grind the 1000 boots to fit) but also because after less than 12 months the boots I've been using are all seriously cracked. Not yet leaking, but it seems imminent.
Failing these, I'm hoping someone can point me in the right direction, maybe to XS650 holders or something.
2001 ZX-6R
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: BS34 750 carb boots - part number confusion
27 Mar 2021 12:00
#845609
Partzilla indicates they have them in stock, but do not indicate how many or how much.  You need to log in to see price.
www.partzilla.com/catalog/kawasaki/motor...750-n1/cylinder-head
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: ghostdive
  • Nessism
  • Nessism's Avatar
27 Mar 2021 13:12
#845613
Yup, buy OEM Kawasaki parts.  The safe bet.
  • ghostdive
27 Mar 2021 19:26
#845637
I completely forgot about that option - I figured OEM would all be hard as rocks from sitting. I'll give it a try. Thanks to you both!
2001 ZX-6R
  • SWest
  • SWest's Avatar
  • 10 22 2014
