RS38 Mikuni
  • Jerryvan
  • Jerryvan's Avatar Topic Author
  • Send it
RS38 Mikuni
23 Nov 2020 19:46
#838809
Hey all, I need some quick advice. I got a project kz1000b (79LTD) with vm26 and I can't tune them. I have an evaporating by the minute opportunity to buy a set of Mikuni RS 38 Series Carburetor cheap. Too much carb for a stock bike with pods and a no baffles exhaust? Next year or soon later I'll be probably putting a 1075 piston kit but not for a while
Kz750 (81)
Kz1000 (79)
3 Kz650 (2-79's)
1 650 CSR for parts
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: RS38 Mikuni
23 Nov 2020 20:56
#838814
Ran a set of RS36's on my KZ1100, and was advised by fellow forum members they were too big. RS34's have been great, even considering the engine has since become an 1135 with a stock 84 bathtub head and ZX1100A camshafts.
I think RS36's would still be too big with the current engine setup.
B)
1982 KZ1100-A2
  • Jerryvan
  • Send it
Re: RS38 Mikuni
23 Nov 2020 22:07
#838815
No kidding, that's disappointing. I read on a supplier's website that 34's were too small for 1000cc and recommend for 750cc or less.
Kz750 (81)
Kz1000 (79)
3 Kz650 (2-79's)
1 650 CSR for parts
  • DoctoRot
  • DoctoRot's Avatar
Re: RS38 Mikuni
24 Nov 2020 09:44 - 24 Nov 2020 09:46
#838850
Cant just look at CCs alone. Need to look at target HP and application as well. 34s are probably a little to big for a stock KZ1000 engine but they will work.
Last edit: 24 Nov 2020 09:46 by DoctoRot.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: RS38 Mikuni
24 Nov 2020 10:42
#838859
Don't take my comment as a recommendation or direction for your particular situation.
Please consider what other members suggest before making your decision.
1982 KZ1100-A2
  • tomsbadkz
  • tomsbadkz's Avatar
Re: RS38 Mikuni
24 Nov 2020 16:32
#838890
Here's a thought. If its great deal, you could buy them and Im sure someone would jump on a trade for the 34s. I am currently running 38s on my 1327 motor and it works incredibly. Tom
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
  • Jerryvan
  • Send it
Re: RS38 Mikuni
27 Nov 2020 06:01
#839037
With head choice you made, the bathtubs, did you compensate with higher compression pistons? I read you can loose 2 points due to the camber size?
Kz750 (81)
Kz1000 (79)
3 Kz650 (2-79's)
1 650 CSR for parts
  • zed1015
  • zed1015's Avatar
  • Away
Re: RS38 Mikuni
27 Nov 2020 07:18
#839040
Jerryvan wrote: With head choice you made, the bathtubs, did you compensate with higher compression pistons? I read you can loose 2 points due to the camber size?
That only applies if using the bathtub head on the earlier KZ903/1015cc kickstart motors.
The later J and GPZ non kickstart equipped all share the same 40cc volume combustion chambers ( the earlier KZ's are 36cc ).
