Odd question? How do you measure for spring clip fastners for a 13mm fuel line?
- Ninja1195
25 Jul 2020 18:40
I need to order some clips for my new 13mm (ID 5/16") fuel line. I assume that 13mm clips will be too large and slide off? 11mm or 12mm the way to go?
Suggestions?
Suggestions?
1978 KZ650 B2
Re: Odd question? How do you measure for spring clip fastners for a 13mm fuel line?
25 Jul 2020 21:46 - 25 Jul 2020 21:49
Check here they have about 8 different sizes. I have used them several times... fast shipping and reasonable price.
www.partsnmore.com/parts/?filters [category]=air+%26+fuel%2Ffuel+line+%26+accessories&q=hose+clamp
Last edit: 25 Jul 2020 21:49 by Mikaw. Reason: spelling
26 Jul 2020 07:27
The fuel line & clamp size should be the ID, and the OD of the fuel line will be larger, so the same size clamp should fit.
The following user(s) said Thank You: Ninja1195
- gavroyer
26 Jul 2020 12:38martin_csr wrote: The fuel line & clamp size should be the ID, and the OD of the fuel line will be larger, so the same size clamp should fit.
I think 13mm is the OD of his fuel line. The 5/16" line is a tiny bit bigger than 8mm ID.
1980 KZ440-A1 LTD
26 Jul 2020 12:51
What nice about the site I posted is they list the clamps in the ID size. Measure to OD of your hose and get one size smaller...
- Kidkawie
- I bleed premix
26 Jul 2020 18:07 - 26 Jul 2020 18:08
You choose the clamp size by the hose outer diameter.
Whoever manufactures the clamps factor in clamping pressure, no need to go down a size.
www.mcmaster.com/hose-clamps/clamps-and-...-firm-hose-and-tube/
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 26 Jul 2020 18:08 by Kidkawie.
- Rick H.
27 Jul 2020 12:23
I have been getting a lot of my small hardware items including hose clamps from a place called Belmetric. Great people to deal with and ship very quickly in most cases. I have used a bunch of their Fuji locknuts. Here is a link:
www.belmetric.com/
Rick H.
www.belmetric.com/
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
- cb900f
27 Jul 2020 13:29 - 27 Jul 2020 13:29martin_csr wrote: The fuel line & clamp size should be the ID, and the OD of the fuel line will be larger, so the same size clamp should fit.
That doesn't make sense as the thickness of the hose material is different depending on on the type and who is manufacturing the hose, i.e. the OD of one manufacturer's hose can be larger or smaller than another manufacturers hose even though both hoses have the same ID.
Last edit: 27 Jul 2020 13:29 by cb900f.
- Dr. Gamma
27 Jul 2020 13:49 - 27 Jul 2020 13:53
Just twist up a piece of safety wire to the size of your fuel line.
Works great, been doing it since back in the 70's!!!!!
1986 RG500G 2 stroke terror.
Last edit: 27 Jul 2020 13:53 by Dr. Gamma.
27 Jul 2020 15:58
I don't run a clamp. If you use OEM type stretchy fuel line that properly fits the petcock nipple it won't leak.
27 Jul 2020 19:11 - 27 Jul 2020 19:13Nessism wrote: I don't run a clamp. If you use OEM type stretchy fuel line that properly fits the petcock nipple it won't leak.
This may be true, but the KZ650 bikes came from the factory with clamps. I suspect other models also came with clamps. Of course the original clamps were a bit wimpy. :laugh: Ed
Last edit: 27 Jul 2020 19:13 by 650ed.
28 Jul 2020 07:30 - 28 Jul 2020 07:50
By cb900f: That doesn't make sense as the thickness of the hose material is different depending on on the type and who is manufacturing the hose, i.e. the OD of one manufacturer's hose can be larger or smaller than another manufacturers hose even though both hoses have the same ID.
It's a general rule I use. OP was wondering about the clamp sliding off the hose. In cases where the fuel line wall is thick, then a guy has to use some common sense to decide what clamp to get. Some clamps are sold to fit a range of fuel line sizes, so this often times accounts for the varying wall thickness, and going by the I.D. is a simple rule. Not that I buy clamps very often, but I've never had a problem buying a hose clamp. I like Moose clamps.
Last edit: 28 Jul 2020 07:50 by martin_csr.
