VM24 carb kits
- 750 R1
Re: VM24 carb kits
16 Jul 2020 19:03martin_csr wrote: By 750 R1: Thanks Ed, Its had a 700cc kit put in it 500 miles before it went into storage, the carb kits I've looked at had a variety of jets so I thought it would make sense to use one, I definitely want to change the o rings and gaskets, Carbs will be pulled apart separately. Anyway, back to the question, are the VM24 carbs basically the same ?
Were the carburetors rejetted or tuned for the 700 kit? I'd guess you'd need larger main jets, maybe #17 pilot jets & maybe shim the jet needles to raise them.
I haven't checked in a while, but I've never seen carburetor kits for the 81 KZ650-CSR. I just disassembled & cleaned everything, then installed new gaskets & o-rings. There are 2 or 3 different float bowl gaskets, so verify which ones you have before ordering. A metric nitrile o-ring kit from HarborFreight had most of the needed sizes except for the starter plunger o-rings which I got from the dealer, but Z1Enterprises.com may have them.
Thanks Martin. The guy we bought the bike off didn't know a great deal about what was done, it had pods on it which we are removing and putting on an airbox, so I imagine what ever jetting was used will no longer be relevant . The guy that's doing the carbs up for us is extremely competent so we should be able to get it all sorted. I just couldn't find anything specifically for the 81 model, we've ordered a carb kit so i'll update what we find.... Its not a CSR, its a KZ 650F..
- 750 R1
Re: VM24 carb kits
16 Jul 2020 19:09
I've just found out that the KZ650F2 wasn't sold in the USA, so most of my searching turned up nothing, now I know why...!!!
Re: VM24 carb kits
16 Jul 2020 20:40
You may find some KZ650-F2 info here interesting......
jarlef.no/Kawasaki/Series/Z/650/Z650F.htm
www.cyclechaos.com/wiki/Kawasaki_KZ650F
diagrams.kz650.info/wiring/images/KZ650-F2.jpg
The following user(s) said Thank You: 750 R1
- gd4now
- Denco where did you go?
Re: VM24 carb kits
16 Jul 2020 22:06
Microfiche for F2 F3 F4 can be found here
z650.surr.fr/
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- 750 R1
Re: VM24 carb kits
17 Jul 2020 17:39 - 17 Jul 2020 17:40
Thanks for the links ...! While you guys are here, anyone have a spare seat lock ?
Last edit: 17 Jul 2020 17:40 by 750 R1.
