KZ1000 won't start after carb cleaning 11 Jul 2020 11:06 #830374
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1674
Kidkawie wrote: Do yourself a favor and install a Dyna pickup.
+1
KZ1000 won't start after carb cleaning 11 Jul 2020 11:21 #830375
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 255
TSK, TSK, TSK....Dyna's are for girls! Points and condensers are for men!!!
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
KZ1000 won't start after carb cleaning 11 Jul 2020 11:43 #830377
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1890
Rick, be carefull. A lot of Dyna pussy´s reading here.... :laugh: :laugh: :laugh:
KZ1000 won't start after carb cleaning 11 Jul 2020 15:02 #830392
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
  • Thank you received: 244
Rick H. wrote: TSK, TSK, TSK....Dyna's are for girls! Points and condensers are for men!!!
Rick H.
You must send text messages via smoke signals.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
KZ1000 won't start after carb cleaning 12 Jul 2020 05:35 #830443
  • magilla
  • magilla's Avatar Topic Author
  • Thank you received: 3
Well, the issues with the lighting circuits must have been related to the moisture, because when I started trying to track down the shorts, the voltages were back up to 12.5V on both of those circuits with no overheating of the fuses. It has been hot and dry here for several days. It was great to get the bike out again, I rode about 60 miles yesterday. I think I need to adjust the carbs. After riding about 30 miles, the bike seemed to be missing a little at idle, and I couldn't adjust the idle down any lower than about 2,000 rpm. The idle setting procedure in the manual is for the 26mm carbs. Mine are the 28mm carbs that don't have pilot screws on the bottom. There are adjusting screws on the tops, are these the pilot screws?
1979 KZ1000-B3 LTD
Carrollton, Illinois
The following user(s) said Thank You: Oncle Raoul
Last edit: by magilla.
KZ1000 won't start after carb cleaning 12 Jul 2020 08:16 #830455
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 306
I'm glad the bike sorted itself out electrically.
Thanks for the update.
The others will be able to help you out on the fueling side. :)
81-KZ440-D2.
LIC, NY
Last edit: by F64.
