Carb cleaning on bike
- fuzz0912
- Thank you received: 2829
You can install an inline shutoff valve until you correct the petcock problem and that will stop the flow of fuel when the engine is shut off if you manually turn that valve to the off position, but the carb problem will still be a problem whenever that shutoff valve is turned to the on position. So the bottom line is you need to correct both problems. Ed
- loudhvx
- Thank you received: 1616
Another possibility on the TK22 carbs you have, are the bowl drain screws. They act like little valves which allow for the draining of gas, and for using the drain line to check fuel level. There are two orings on each drain screw. Make sure they are good and everything is clean. Those screws do not need to be tight to seal and should never be cranked tight. If they don't seal by being snug, an oring is probably bad.
The petcock can be very easily tested by simply pulling off the fuel line and seeing if it drips. After several minutes it should stop dripping and completely.
In my signature there is a link to a Tk22 carb website and a bunch of online manuals. Also, make sure to read the valve train warning.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- fuzz0912
- loudhvx
If the lever is in the "pri" prime position gas will flow. Make sure it's set to "on" or "res".fuzz0912 wrote: so I'm fairly sure the petcock is stock. It is leaking. I had the gas lines off of the tank a few days ago and fuel was flowing, so its not shutting off like it should.
Not really, at all.fuzz0912 wrote: When it comes to cleaning the carbs and checking everything can that be done on the bike?
Yes. they will get slightly out of sync, but nothing major. The bike will still run ok afterward, but just a little rough maybe. You will have to sync them to restore smooth idle.fuzz0912 wrote: And if not do I have to worry about getting the carbs out of sync when I pull them off.
You don't need to ungang them to just clean out the bowls and check the jets. But don't soak them in anything unless you plan totally separate and disassemble them. It's often not needed and will cause more problems that it will solve. Some of the seals for the shafts are not available. You just probably need to replace the fuel valves and pull the jets and clean them using guitar strings as pokers. You don't really need to do anything with the throttle slides or needles as long as they look good and feel smooth. A drop of oil on the moving parts might help. The choke plates need inspecting for sure, to make sure the flaps are intact. The website shows what to look for.
The hardest part will be putting them back on. It will be the opposite of pulling them.
Pulling them is also hard. Read the manual on which screws to loosen to make the airbox move backward. It only moves backward slightly, but that will make a difference. Remove the throttle cables. Remove the hose clamps or at least make them so loose that the screws are almost not attached. The boots have to expand very far to release the carbs. Roll-off the airbox spring clamps. They can stay on the boots. Sit on the bike on a center stand and put your feet on the engine castings and pull the carbs back hard into the airbox until the carb outlets can be nosed out of the engine carb mounts. Then wiggle them out over the boots which will release them from the airbox boots.
There is a website for your carbs. The maintenance page will show how to set them dry, but you should read the manuals on how to set them using a site tube.fuzz0912 wrote: And how does one set the fuel level for the carbs?
1981 KZ550 D1 gpz.
Other links.
- fuzz0912
- fuzz0912
- fuzz0912
- fuzz0912
- Rick H.
- Thank you received: 255
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
