1979 KZ 650 carbs
- Scooter 650
1979 KZ 650 carbs
18 Mar 2020 07:39
I have a 79 KZ 650 Sr my number 2 carb keeps sticking as in the bike will start on choke number 2 cylinder isn’t getting gas. If I whack the number 2 carb with a wrench work the choke and throttle it will start working and the bike will run fantastic all day. Let it sit for a day or two it’s the same dance to get it running again. This bike has the pumper carb #2. It was setting for 20 years I cleaned the carbs and fixed it up over the winter. Is this a stuck closed float needle? Or could it be something else
- baldy110
Re: 1979 KZ 650 carbs
18 Mar 2020 09:21
Sounds like the pilot circuit in the carbs need cleaning.
- Scooter 650
18 Mar 2020 09:38
Could be but why would it work if I smack it with a wrench? I don’t think there are moving parts in the pilot circuit maybe loose dirt? Also when it does this the bike will only run on choke but not at high rpm like it’s on choke it will stall if you give it gas smack carb #2 for a bit and it runs properly
- jayrodoh
18 Mar 2020 09:54
Definitely sounds like the needle is sticking. When I rebuild carbs I like to polish the inside of the seat with some brasso and a q-tip in a drill. Smooth surface for both the needle to seat and smooth sides so the needle does not get hung up.
1982 KZ750-M1 CSR
The following user(s) said Thank You: Scooter 650
- Scooter 650
18 Mar 2020 10:02
Thanks that’s what I figured. I did clean them with q tips but that polishing idea is awesome I will add that to my bag tricks. if it doesn’t clear up with use I will take off the carbs and give it a shot
- baldy110
18 Mar 2020 11:42
Running only on choke is classic symptom of clogged / dirty pilot circuit. Polishing the seat is a good idea and STOP hitting it was anything.
- jayrodoh
18 Mar 2020 11:53baldy110 wrote: Running only on choke is classic symptom of clogged / dirty pilot circuit. Polishing the seat is a good idea and STOP hitting it was anything.
True but I think he was stating that it only ran with the choke on until he taps the bowl to unstick the float/needle. After that it runs fine.
1982 KZ750-M1 CSR
- Scooter 650
18 Mar 2020 14:12
Yep only after tapping on the carb aggressively so something mechanical is stuck. Then it runs good until it sets for awhile.
- baldy110
- Scooter 650
18 Mar 2020 15:24
If you had read my original post you would see I had the carbs apart and cleaned them over the winter. I don’t think my pilot jets or air passages have plugged up in the 6 days that the carbs have been back on the bike. But I guess it could be possible. I also replied if the issue continues I will remove the carbs and go through them again.
18 Mar 2020 16:07
Did you take the carbs fully apart and soak all the hard parts in carb dip? Replace all the soft parts like O-rings and gaskets? Perform a vacuum sync after getting the bike up and running?
- Scooter 650
