Keihin CR or Mikuni flat slides?
- ACaveKZ1075
29 Jan 2020 17:16 - 30 Jan 2020 12:49
Currently running Keihin vacuum carbs and want better response but i am torn between the Keihin CR carbs and the Mikuni flat slides. Running a 1075cc. I live in florida
ment=132143]9d67d6ae4d9a42df8dbde42baaa28cb1[/attachment]
77 KZ1000 CHUBBER
Last edit: 30 Jan 2020 12:49 by Street Fighter LTD. Reason: Pics didn't work
Re: Keihin CR or Mikuni flat slides?
30 Jan 2020 04:23 - 30 Jan 2020 04:25
I would say--
First choice Keihin CR if you can find them and at a price that doesn't make you faint.
Second choice Mikuni RS, can be a bit finicky to set up, but great when dialed in. Usually easy to find and only kind of expensive.
Lectrons. Do not even consider for a street bike. They are designed for wide open throttle operation, and pretty much suck at anything else.
P.S. Can't see your pics. It seems to be better to insert them rather than link to a hosting site.
Last edit: 30 Jan 2020 04:25 by TexasKZ.
The following user(s) said Thank You: Dragbike_Mike, ACaveKZ1075
- ACaveKZ1075
30 Jan 2020 05:45
At z1enterprises they're almost the same price point. Looking at dropping a grand anyway. Thank you for the reply!
77 KZ1000 CHUBBER
- ACaveKZ1075
- Dragbike_Mike
30 Jan 2020 09:19TexasKZ wrote: I would say--
Amen, brother!
Mike
Presently - 1980 KZ1000B4 LTD w/mild ported head, Megacycle cams, 1015cc Wiseco, Falicon Supercrank, R&D undercut trans
The following user(s) said Thank You: ACaveKZ1075
- ACaveKZ1075
30 Jan 2020 09:21
Thanks mike! Can you guys see the pics now?
77 KZ1000 CHUBBER
30 Jan 2020 11:16 - 30 Jan 2020 11:19
I fixed your pictures to enlarge them, Next time hit the insert all tab to complete picture posting
If not racing , and wanting more responsiveness I would find a set of stock 26mm or some 28mm carbs and just jet them to run correctly.
Small 26 mm carbs would be snappy as air flow is higher at lower rpms
Pipe looks good for chosen design but will be real loud . Tuning may be tricky too
Enjoy
Enjoy
Last edit: 30 Jan 2020 11:19 by Street Fighter LTD.
- ACaveKZ1075
30 Jan 2020 11:55
Thank you dave! Everyone has been awesome on this forum for my first post. Yes they are very loud! They get a nice dissonance running cylinder 1 and 2 then 3 and 4 together. Sounds like a v- twin and an old kaw inline hybrid unbaffled. Very pleased with the result. Sorry there's no pics of it tigged together. I'm gonna run a high polish on the pipes as they are stainless.
77 KZ1000 CHUBBER
30 Jan 2020 15:31 - 30 Jan 2020 16:08
Here is another source for Mikuni RS
kzzone.com/carbs.html
And another
dynoman.net/carb/mikuniRS2.html
And a source for Keihin CRS
dynoman.net/carb/keiCR.html
And another for both
www.pjmotorsports.com/index.html
And another
Last edit: 30 Jan 2020 16:08 by TexasKZ.
30 Jan 2020 15:41ACaveKZ1075 wrote: At z1enterprises they're almost the same price point. Looking at dropping a grand anyway. Thank you for the reply!
Z1E sells Keihin CR carbs? I have looked a couple of times and not found them.
- ACaveKZ1075
30 Jan 2020 17:55
My mistake..... their sister site carries them dime city cycles. I always forget the distinction because i live minutes away from their office/ warehouse, but they're all under revival . Z1enterprises, randakkscycleshack, mikesxs, and dimecitycycles.
Here's a link to the CR 33s but they have up to a 35.
www.dimecitycycles.com/vintage-cafe-race...retor-016-3079.html#
77 KZ1000 CHUBBER
- DoctoRot
31 Jan 2020 10:12 - 31 Jan 2020 10:12
Whoa, whoa, whoa, were gonna need more pics of that chopper. did you fabricate that header? looks crazy!
Last edit: 31 Jan 2020 10:12 by DoctoRot.
