Mikuni vent tube
- 73z1
Mikuni vent tube
08 Nov 2019 13:37 - 08 Nov 2019 13:38
I need a vent tube, tube inside bowl is .140", tube outside bowl is .158", two tubes I think, pressed into bowl.
All advice appreciated.
Last edit: 08 Nov 2019 13:38 by 73z1.
Re: Mikuni vent tube
08 Nov 2019 14:52
Is it leaking?
- baldy110
08 Nov 2019 15:43 - 08 Nov 2019 15:44
Google K&S brass tubing. The diameter can be flared out using a small drill bit (the back side) forced inside.
Last edit: 08 Nov 2019 15:44 by Nessism.
08 Nov 2019 20:14
That looks like a late '74 to 75 Z1 carb bowl. You're not putting that on your '73 resto are you?
- 73z1
09 Nov 2019 05:26 - 09 Nov 2019 05:27
>>> "Is it leaking? "
The tube broke of the bottom of a carb, I want to fix so I can attach drain hose.
>>> "That looks like a late '74 to 75 Z1 carb bowl. You're not putting that on your '73 resto are you? "
The 73 has original carbs and bowls.
I am building two more engines, where I started hole sawing pistons.
Last edit: 09 Nov 2019 05:27 by 73z1.
