Where to find vacuum diaphram
  • Willjoel13
  • Willjoel13's Avatar Topic Author
16 Oct 2019 11:10
#812557
I have a 1983 kz 550 f1 shaft. The throttle vacuum valve diaphrams are stiff and need replacements. Any ideas on where to get just the rubber part?
I'm new to this forum btw. TIA.
  • TexasKZ
  • TexasKZ's Avatar
Re: Where to find vacuum diaphram
16 Oct 2019 11:42
#812558
Evidently, they are still available from Kawasaki.
www.partzilla.com/product/kawasaki/16126...2cee54355cc549e7ebae
  • Rick H.
  • Rick H.'s Avatar
17 Oct 2019 13:08
#812608
WOWSERS! Those are expensive little devils aren't they...…$191.00 retail.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • TexasKZ
  • TexasKZ's Avatar
17 Oct 2019 14:56
#812615
Yes, they are. For most of these old bikes, the diaphragms are either shockingly expensive or not available at all.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
17 Oct 2019 15:48 - 17 Oct 2019 15:51
#812618
Rick H. wrote: WOWSERS! Those are expensive little devils aren't they...…$191.00 retail.
Rick H.
Same part number on Ebay:
1982 KZ1100-A2
Last edit: 17 Oct 2019 15:51 by daveo.
  • Mikaw
  • Mikaw's Avatar
17 Oct 2019 16:00
#812619
I have saved money by taking the part number and an afternoon and calling Kawi dealerships and asking them to check their stock.. you get them much cheaper even with shipping.. a little time and a few phone calls voil'a
The following user(s) said Thank You: loudhvx, martin_csr
  • Rick H.
  • Rick H.'s Avatar
18 Oct 2019 06:00
#812643
Rick H.
Still $90.00 USC plus shipping but much better than $191.00. Unfortunately, when you NEED something you are at the sellers mercy. I know from things I have purchased.
Rick H.
Rick H.
  • loudhvx
  • loudhvx's Avatar
18 Oct 2019 07:21
#812654
The problem is that they integrated a flimsy, cheap rubber part with an expensive, machined metal part with no easy way to remove the rubber part. You have to break the plastic attachment rings to get the diaphragm off.
I went down a rabbit hole of research for a similar problem on Kz400's. Some companies are making a replacement rubber part, but making it different so it can be retrofitted to an old slide where the attachment rings were broken off. This involves molding in a heavy band where the diaphragm holds the slide. These guys might save these bikes. But so far, I don't know if they've come up with a replacement for the KZ550's TK26 carbs or ZX550's TK27 carbs.
  • azman857
  • azman857's Avatar
18 Oct 2019 21:29
#812697
Have you tried JBM industries? They make just the CV diaphragms to put on your slides. Carb holders too.
  • Willjoel13
19 Oct 2019 06:28
#812706
I tried a few different diaphrams for old Harleys and several other mikunis. None of them are a good fit. What about a retrofit with an older set of kz550 carbs? Its easy enough yo change the manifold boots and jets. I did some shopping around and found used sets as low as $100. That plus rebuild kits and boots would be around a $200 fix. Keep in mind, this is a total revamp bike I picked up, so I have plenty of time to work on it.
  • loudhvx
  • loudhvx's Avatar
19 Oct 2019 09:58
#812711
The newer engines had the carb-holder mounting bolts farther apart so the older carb-holders don't just bolt-up. they have to be modified. The holes have to be made into slots. Also the sealing surface is reduced so you have to really watch for vacuum leaks.
The following user(s) said Thank You: Willjoel13
  • Willjoel13
20 Oct 2019 06:17
#812749
I was aware of the modifications to the carb holders. Of course I'll have to do some jetting on the older ones because the shaft driven had lager jets to accomadate the extra load. But it seems that a small modification and around $200 is the way to go. Anywhere from 650 to 800 bucks to get a flimsy rubber diaphram is just not a smart option in my opinion. This bike is already undergoing a lot of modernization. (All led lighting, digital Speedo, new handlebars, exhaust reconfiguration, ECT.). If I were looking to restore it, I'd spend the money, but I just want to ride this bike with a few comfort and asthetic upgrades. Thanks for all of the info guys! I look forward to sharing the journey on this bike with all of you.
