1980 kz550 ltd. Motorcyle lags after few minute of riding.
- geneaskew
05 Aug 2019 11:57
Hope someone can help me here. Been trouble-shooting this problem for weeks now, and can't figure out what's the problem.
Bike starts up easy, runs well with choke on, though it does belch some smoke. Hey it's an old bike, I get that. On my daily commute she runs well for the first few minutes, then at about the same point each daily trip, performance falls, the bike starts lagging, sounding/running rough, and I have to keep on the gas a little during idling so it doesn't stall. This will last for a couple more minutes, then the bike surges, and returns to normal performance.
Over the last few weeks, I've done the following: changed spark plugs, air filter, and fuel lines; rebuilt the fuel tank petcock; drained out the tank and carbs; sprayed carb cleaner in to carbs while bike is running; and finally put a can of Berryman's B-12 fuel treatment in the tank.
While I've noticed some improvement, and many times the bike runs without fault, other times I'll notice the same loss of power and rough running for a short spell.
Any ideas?
Any ideas?
Re: 1980 kz550 ltd. Motorcyle lags after few minute of riding.
05 Aug 2019 13:08
Did move the ignition Timing advancer freely, (cleaning and some lube)?
Valve clearence checked?
- Amjohn
05 Aug 2019 14:16
Had very similar problems to this on my z500, turned out to be worn needle jet tubes, check out mine, replaced them with new and all those issues went away. Initially I thought it was ignition timing, then air leak, then went down the whole list but problem kept returning. Photos of old and new tubes below. Ps new tubes are almost impossible to find for TK carbs
- baldy110
05 Aug 2019 15:20
Are you riding it with the choke on?
- geneaskew
06 Aug 2019 10:59
I use the choke when cold, but close as soon as I think the engine's warm.
- KZQ
- Administrator
06 Aug 2019 14:46
Any chance the vent in the gas cap is plugged? Next time it happens pop the gas cap and see if it doesn't go away.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Bozo
- Ride it like u stole it
07 Aug 2019 03:43KZQ wrote: Any chance the vent in the gas cap is plugged? Next time it happens pop the gas cap and see if it doesn't go away.
Bill
Good call, I forgot about the gas cap venting. Had the same issue on my son's bike , lucky I caught on quickly
- geneaskew
08 Aug 2019 07:42
I had never considered that. Thanks. How does one clean a gas cap vent?
08 Aug 2019 08:11 - 08 Aug 2019 08:24
Here's a couple clips on it.
Start at 14:51
Start at 14:51
Last edit: 08 Aug 2019 08:24 by SWest.
- Kofla
08 Aug 2019 10:01geneaskew wrote: sprayed carb cleaner in to carbs while bike is running
Any ideas?
Spraying carb cleaner while bike is running is not the same as taking the carburetors apart and cleaning them.
1978 Kawasaki KZ-1000 LTD
