New Rider Here - 80's Kz750 4 cyl carb rebuild kit - Why 2 different styles?
- PabstBlueLabatt
21 Jul 2019 20:07
Hi. I am the new owner of an 80's Kz750. There is a leak in the far right carb so I want to fix it and I figured I should just get a full rebuild kit.
On ebay there are two different styles of gasket I've seen for the Kz750:
1. Thin gasket
2. Thick gasket
Can someone tell me why they are different?
1. Thin gasket
2. Thick gasket
- Oldjeep
Re: New Rider Here - 80's Kz750 4 cyl carb rebuild kit - Why 2 different styles?
21 Jul 2019 20:262 completely different types of carbs. The first one is for an 80-82 .PabstBlueLabatt wrote: Hi. I am the new owner of an 80's Kz750. There is a leak in the far right carb so I want to fix it and I figured I should just get a full rebuild kit.
1. Thin gasket
2. Thick gasket
What year is your bike
Chuck
81 KZ750 LTD
03 FZ1
www.oldjeep.com
81 KZ750 LTD
03 FZ1
www.oldjeep.com
21 Jul 2019 20:35
PLEASE add your bike's exact year and model to your signature line. Thanks, Ed
22 Jul 2019 05:02 - 22 Jul 2019 05:03
Your bike has Keihin carbs that use an O-ring for the float bowl.
Aftermarket carbs kits like those are very hit or miss; the quality ranges from acceptable to pure junk. It's a big gamble. You would be better off opening up the carbs and inspecting what you have and reusing all but the soft parts like O-rings and possibly float needles (which have a rubber tip). I've posted all the required O-ring sizes previously in different older threads so some searching should turn up that information pretty easily.
Oh, and cracked float bowl overflow tubes is very common on those Keihin's, which will cause overflow like described. I've posted information on how to fix those previously too. Please search and PM me if you can find the threads.
Last edit: 22 Jul 2019 05:03 by Nessism.
22 Jul 2019 06:53 - 23 Jul 2019 05:36
By Oldjeep: 2 completely different types of carbs. The first one is for an 80-82....
That's not exactly correct about the years. The o-ring type gasket was also used on at least one 83 model & the flat fiber gaskets were used on the 82 GPz. So he does needs to indicate what model it is & maybe post a pic to make sure of what he's got.
Last edit: 23 Jul 2019 05:36 by martin_csr.
22 Jul 2019 06:57
The 1980 would be Keihin. No Mikuni on the 750 until 1982.
22 Jul 2019 07:12
He didn't specify a year. He just said it's an 80s 750, so who knows what he's got.
- Nerdy
22 Jul 2019 08:28
You guys?
The user who posted this really vague question is highlighted as 'banned'. If the ban is accurate, we can probably guess who it is. I'm not sure why anyone is trying to answer him.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
22 Jul 2019 08:34
I don't think it's our friend Jeff. He was banned for business name as a user name.
- Nerdy
22 Jul 2019 10:10SWest wrote: I don't think it's our friend Jeff. He was banned for business name as a user name.
Ah, fair enough - thanks.
There was an Austrian film director named G. W. Pabst. There's no excuse for the Labatt, though.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
