Help on diagnosing lean condition
  • dpivas7
  • dpivas7's Avatar Topic Author
12 Jul 2019 05:30
#807417
I have pod filters on my KZ750E engine with 1982 KZ750 LTD carbs (no overflow tube in float bowl). I also am running a Delkevic exhaust with the primary baffle removed. Originally, I had a DynoJet stage 3 kit installed (slide hole drilled, slide clip moved to groove 4, and mixture screw turned out 3.5 turns), but I also upped the Primary Main Jet to 70 and the Secondary Main Jet to 140, per suggestions on this site.
I'm confused as to why I'm running lean even though I've upped the jet sizes. The bike ran okay with the DynoJet kit, but struggled under load which is why I upped the jet size. Now the carbs pop when I give it gas and it is incredibly difficult to start. I have yet to check the valve lash BUT if that was a problem, why didn't I have any valve clearance symptoms when the jets were smaller?
Current: '19 Harley Roadster, '72 XLCH, '84 GPz 550
Past: '84 GPz 550, '82 KZ750 LTD, '71 XLCH
Re: Help on diagnosing lean condition
12 Jul 2019 05:39
#807418
Good luck getting those CV carbs to work properly with pods. Maybe the video in the link below will help. If you do get them working as well as the CV carbs work with an airbox be sure to post the info here for others who suffer the same problems. Ed
  • TexasKZ
  • TexasKZ's Avatar
12 Jul 2019 07:10
#807421
Check the valve lash. Trying to adjust the carbs on an engine with badly out of adjustment valves is an exercise in futility.
A lean condition can cause popping in the exhaust system. Backfiring through the carbs is a different thing altogether. It is often the result of an intake valve not closing.
Hard starting can be due to clogged pilot system or a wildly rich condition from improperly set fuel level.
Also keep in mind that the different carburetor systems do not operate diacretely. The pilot system regulates idle mixture, but as soon as you open the throttle, the needle starts to function, then the primary main starts to function, and it is overlapped by the secondary main. Changing two at a time can create unexpected results down the line.
One of the preferred methods to get the jetting spot on in carbs with three circuits is to start with the main jet. It is primarily responsible for 3/4 to full throttle. Once throttle response there is as crisp as can be, then do roll-one in the mid range to get the needle right, then do low-rpm roll ons to get the pilot jet correct. Since these carbs have an extra circuit, you would need to find out what throttle opening it affects and add that to the procedure.
All of this is a waste if the valves are way out of adjustment.
The following user(s) said Thank You: dpivas7
  • dpivas7
12 Jul 2019 07:11
#807422
Hi Ed,
That helped, but also didn't help lol!
I'm confused about how/when the air passes thru the main intake. It's something I've never understood - why does the jet needle retract when there is air pressure pushing it down? The throttle controls the amount of air passing thru the carb so how can the fuel push the needle up before the air pushes the needle down?
With pod filters, you have to restrict the amount of air passing thru the main intake somehow, so I think if I restrict it or redirect the air between the pod filter and the main air intake of the carb, I should be good... but we'll see how easy that is.
  • dpivas7
12 Jul 2019 07:20
#807423
Hey Texas,
My intuition was that the carburetor popping was due to valve lash, but my coworker who knows much more than I do convinced me that it was due to a lean condition. That was reinforced by the fact that I didn't have the popping when I had the smaller jets installed. My plan is to check the valve lash - but it's a bit of a lengthy job so I just haven't had the time lately.
I am also going to try to use stock airbox hoses in between the pod and the carb intake. I've read that that the offset shape of the hoses will help since it redirects the airflow by not giving it a direct path to the intake. The indirect path builds pressure slightly and speeds up the airflow which is what I need to make the pods work.
  • TexasKZ
  • TexasKZ's Avatar
12 Jul 2019 07:26
#807425
What?
The air entering the carb is forced under the slide. As the throttle is opened, more air enters, PUSHING the slide UP. At the same time, the low pressure behind the throttle plate creates vacuum that PULLS the slide UP.
Air always goes through the main bore of the carb, but at idle there is not enough velocity to pull fuel up through the main jet. At low throttle openings, the throttle plate creates a low pressure area at the pilot openings, thus pulling fuel through them. Once the throttle is opened enough, he incoming velocity is sufficient to begin raising the slide and pulling fuel from the main jet, which is regulated by the tapered needle. When the throttle is nearly wide open, the slide will be pushed all the way up, so the needle no longer regulates the main jet. At that point, the main jet is responsible for the mixture. Yes, fuel is still coming through the pilot circuit, but it is only a fraction of the overall mixture.
  • TexasKZ
  • TexasKZ's Avatar
12 Jul 2019 07:33 - 12 Jul 2019 07:36
#807426
dpivas7 wrote: Hey Texas,
This is exactly backwards. Smaller jet = leaner mixture.
Backwards. Pods by themselves cause the air to make a 90 degree turn right at the carb inlet. Adding the air box tubes would straighten the air flow into the carb, but I have no idea how you could get the filters to stay on the tube and how you could possibly get all that to stay on the carbs without some Rube Goldberg support system.
Last edit: 12 Jul 2019 07:36 by TexasKZ.
  • dpivas7
12 Jul 2019 07:35
#807427
So you mean that air coming makes it's way into the float bowl? That's the only way the needle could get pushed up, isn't it?
  • TexasKZ
  • TexasKZ's Avatar
12 Jul 2019 07:38
#807428
No. The air goes under the slide. Between the slide and the bottom of the carb bore. The next time you have the carbs off, take a close look and you will see that the slide does not seal against the bore.
  • dpivas7
12 Jul 2019 07:43 - 12 Jul 2019 07:43
#807429
Correct. I didn't think I had a lean mixture with the small jets. So when I increased the jet size and I spoke with my coworker, he convinced me that there was something else causing the lean mixture which is why I wrote "I'm confused as to why I'm running lean even though I've upped the jet sizes."
Now I believe that it's probably not lean.
The pod filter is attached in line with the air intake on the carb body, so I don't understand how they need to take a right turn. This is what I was thinking of doing:
Last edit: 12 Jul 2019 07:43 by dpivas7.
  • TexasKZ
  • TexasKZ's Avatar
12 Jul 2019 07:45
#807430
Also, if you have cheap filters, they may be covering the pilot air jet, which will make tuning the carbs impossible. APE, K&N, and Uni are the safe bet.
  • TexasKZ
  • TexasKZ's Avatar
12 Jul 2019 07:49
#807431
The air enters the side of the filter, then has to turn 90 degrees to line up with the carb bore. Those filters already seem to have a tube of sorts between themselves and the carbs. Usually, there is nothing more than a small lip sticking out of the filter.
