Replacement parts
- jarellano119
Replacement parts
27 Apr 2019 19:23
does anyone know the size and thread of the screws for the float bowls and diaphragm covers? majority of mine are stripped.
also where does everyone buy other carb replacement parts ie. gaskets, diaphragm's, floats and fuel lines? not sure what has been done to these carbs before so id like to start fresh and do an over haul.
80-81 kz650 csr
Mikuni Carb VM24ss
80-81 kz650 csr
Mikuni Carb VM24ss
Re: Replacement parts
27 Apr 2019 20:42
Are you sure it's the screws that are stripped and not the screw holes in the carbs? Also, you mention diaphragm covers but you show the carbs as Mikuni VM24SS types - so what diaphragm covers are you talking about? Ed
27 Apr 2019 20:43
The screws are standard M4 and M5 type. As for a good source of parts Z1 Enterprises is hard to beat. Reusing all your old Mikuni jets is safe money, just pick up new O-rings and other needed soft parts.
While this tutorial is not geared to Kawasaki's it should help regardless... members.dslextreme.com/users/bikecliff/i.../vm_carb_rebuild.pdf
The following user(s) said Thank You: jarellano119
- jarellano119
28 Apr 2019 03:56
Yeah the phillip head screws are stripped. I've replaced them on my vstar with hex cap screws so I'd like to do the same on the kz.
Thanks for the info.
28 Apr 2019 07:16 - 28 Apr 2019 07:17jarellano119 wrote: Yeah the phillip head screws are stripped. ...............
Keep in mind that there are no phillip head screws on any KZ. The screws that look like phillips are actually Japanese Industrial Standard (JIS), and using a phillips screwdriver on them can quickly ruin the screw heads because the pointed tip of the phillips screwdriver prevents the tool from fully engaging the slots in the screw (see image below). One needs to use JIS screwdrivers on them. This is true of all the crosshead screws on a KZ. Let me know if you need more info on this subject. Ed
Last edit: 28 Apr 2019 07:17 by 650ed.
28 Apr 2019 08:08 - 29 Apr 2019 12:19
Edited. not sure what year the motorcycle is. the 1982 KZ650-CSR has BS32 carburetors.
Last edit: 29 Apr 2019 12:19 by martin_csr.
- jarellano119
28 Apr 2019 11:07
This is exactly what I needed. am compiling a list of items but seems they're mostly 1 or two small things which seem to be the hardest to find.
28 Apr 2019 15:01 - 29 Apr 2019 11:10
Partzilla has the part numbers. Then search EB or Z1Ent.
In the diagrams the size is listed for some of the fasteners.
Get 5/16" fuel line & 5/16 fuel filter and 1/4" vacuum line.
If you can't find something, post the part number. I've had good luck with K&L parts >> made in Japan.
Last edit: 29 Apr 2019 11:10 by martin_csr.
28 Apr 2019 16:08
OEM fuel line is 7mm and stretchy. No clamp needed. The best stuff is sold by Suzuki. Order fuel line for a GS850 and they give you about 4' of the stuff.
- jarellano119
28 Apr 2019 17:30
you aint kidding about the price for the diaphragm... WOW
thanks guys, was just about to ask about the fuel and vacuum lines! my calipers are out so wasnt sure what sizes to get.
28 Apr 2019 18:00 - 28 Apr 2019 18:48jarellano119 wrote: you aint kidding about the price for the diaphragm... WOW
It is considered polite to answer a simple question – especially a question posed by someone who offered sound advice. In an earlier email I asked what “diaphragms” you were talking about. I asked so I could determine if you really had Mikuni VM24SS carbs as you stated in your initial posting or if you had some other flavor carbs. Simply put – the Mikuni VM24SS carbs do NOT have diaphragms. Consequently, if your carb actually do have diaphragms they are not Mikuni VM24SS carbs. Ed
Last edit: 28 Apr 2019 18:48 by 650ed.
The following user(s) said Thank You: Warren3200gt
29 Apr 2019 05:35 - 29 Apr 2019 12:16
Edited. The motorcycle may be an 82 650-CSR w BS32 carburetors. VM24s w Accelerator pump have either 1 or 2 diaphragms >> an accelerator pump diaphragm & vacuum sensor diaphragm on some of the earlier models.
jarellano119. In case you aren't aware, there's a pdf manual available for the 1981 KZ650, but you'd need the 81-82 manual.
Last edit: 29 Apr 2019 12:16 by martin_csr.
