80's Kawasaki Fuel Injection Systems and E10 (Ethanol) Regular Gasoline
- daveo
24 Apr 2019 08:00
I'm considering purchasing an 83 ZX1100A1 (GPZ) with the DFI reportedly in working condition, and wish to maintain use of it with today's regular E10 ethanol blend gasoline.
All member concerns or suggestions regarding that will be greatly appreciated.
1982 KZ1100-A2
Re: 80's Kawasaki Fuel Injection Systems and E10 (Ethanol) Regular Gasoline
24 Apr 2019 08:37
Should work. Plenty of 80's cars still on the road.
Pics? :woohoo:
Pics? :woohoo:
- daveo
24 Apr 2019 08:57
I'm excited! If she checks out I'll post pics in a day or two.
Otherwise
Otherwise
1982 KZ1100-A2
- fourbrrl
24 Apr 2019 10:25
That system was a bosch utilizing the VAF meter. fuel delivery was "tuneable" using VAF spring tension
I have ALWAYS WANTED an LTD with EFI and shaft !!
PICS PLEASE !!
PICS PLEASE !!
- DFIGPZ
24 Apr 2019 18:59
83/84 GPZ1100 was not that style system no issues with today's fuel most people ditch DFI I think they are foolish for doing so I get them to work fine BTW I have mine For Sale if someone looking for one done ready to ride.
1984 750 Turbo
- daveo
25 Apr 2019 21:13SWest wrote: Should work. Plenty of 80's cars still on the road.
Pics? :woohoo:
Haven't pulled the trigger yet. The bike is a bit rough and needs a lot done to make it roadworthy and safe to ride. I'm hesitant to take on a new/used time and money consuming endeavor.
Still might though...
1982 KZ1100-A2
- old_kaw
26 Apr 2019 09:56 - 26 Apr 2019 11:33daveo wrote:SWest wrote: Should work. Plenty of 80's cars still on the road.
Pics? :woohoo:
Oh hell yes Dave! Especially if the price is affordable. Extra points for a title and keys, although not a deal breaker. IMO That looks to be totally stock survivor, which I would tend to try to keep mostly stock, except in pristine running condition. You already have a red hot rod.
From the safety standpoint, maybe tires and make sure the brakes will stop the bike. Most other things are oil and fluid changes and regular maintenance items. Any fuel related issues can be dealt with. The Bosch fuel injection and was the basis / basics behind the early 80's EFI's and it pioneered a lot of the EFI technology that is still in use today. My turbo Buick had Bosch fuel pressure regulator, fuel injectors, connectors etc.. as did my Peugeot 505, which BTW, the entire Peugeot system was made by Bosch. Tons of info and parts available for this setup, not just Kawasaki info.
Like DFIGPZ, i would never do a carb conversion on something like this. I make stuff like this work.
The gas tank is probably contaminated with varnish, and the fuel pump not working. (just a WAG) Laquer thinner will dissolve the varnish and fuel pumps are available for under 100 bucks.
1981 Kawasaki Kz1000K1
Last edit: 26 Apr 2019 11:33 by old_kaw. Reason: proofreading is a good thing. :-)
26 Apr 2019 10:11
I'd get it if money wasn't an issue.
The following user(s) said Thank You: daveo, old_kaw
- old_kaw
26 Apr 2019 11:16SWest wrote: I'd get it if money wasn't an issue.
You know money is not an issue for daveo. LOL
Now back to the real world.. Check out the Wikipedia article on the GPZ, it has a picture of a slightly cobbled up red 82 GPZ with pod air filters and a carb conversion. Not the best example of this bike I've seen. You should edit the article and add the pics you just posted Dave.
en.wikipedia.org/wiki/Kawasaki_GPZ1100
- daveo
26 Apr 2019 12:17 - 26 Apr 2019 12:24old_kaw wrote:SWest wrote: I'd get it if money wasn't an issue.
My phone camera makes things look ten X better than they are. :blush:
But money an issue it always has been, and so will it continue to be. As long as my engines run good as they can, then I will be a joyful and happy old man.
1982 KZ1100-A2
Last edit: 26 Apr 2019 12:24 by daveo.
The following user(s) said Thank You: SWest, old_kaw
- old_kaw
26 Apr 2019 14:59 - 26 Apr 2019 16:41daveo wrote:old_kaw wrote: You know money is not an issue for daveo. LOL
I completely understand the money thing dave. Money is why I haven't fixed my oil leak. I have almost all of the required parts / gaskets / sealers/ but the 170 bucks for ape studs / nuts is a small stumbling block. Taxes and bike plate renewal this month rates higher than ape studs. Then.. my truck, home, utilities blah blah blah. :pinch: I almost ordered them yesterday, but a loan payment popped up out of nowhere. Who thunk it? :woohoo:
This just cost me ~$250.00 last week, so once again, the studs are on hold.
That camera must do a really good job, because that bike looks great in the pics, compared to a few I have drug home. At the very least it is un-cobbled ( new word?) so far.
This was a few days ago. it is not a good pic, because the bike was in the shade.
Last edit: 26 Apr 2019 16:41 by old_kaw.
26 Apr 2019 15:34
Yeah it cost me a little over $100 with shipping but it was well worth it. Getting ready to go back into the top end again. One less thing to buy.
Next will be the lower end studs.
www.z1enterprises.com/ape-12-piece-hd-cylinder-studs.html
www.z1enterprises.com/24-piece-ape-hd-main-bearing-studs.html
