Pods or stock air box?
- Calvin9819
07 Apr 2019 14:30
Hey guys, I’ve got an 82 kz550 c3 and I was talking to a buddy about it, and he said on bikes like mine I’ll never get the A/F mix right if I go with pod filters, and I should just stick to factory airbox. What do you guys think? And what brand pod filters do you reccomend?
The following user(s) said Thank You: OldguyJoe
Re: Pods or stock air box?
07 Apr 2019 15:08
Your Buddy is right, adjusting A/F on pod filters can be a PITA and for what, looking cool and sounds great???
For me, no thanks but it is your wish and if so take K&N pot filter.
- Nebr_Rex
07 Apr 2019 15:48Calvin9819 wrote: Hey guys, I’ve got an 82 kz550 c3 and I was talking to a buddy about it, and he said on bikes like mine I’ll never get the A/F mix right if I go with pod filters, and I should just stick to factory airbox. What do you guys think? And what brand pod filters do you reccomend?
Check to see if DynoJet or 6 Sigma has a jet kit.
As for filters either UNI or K&N.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- 2strokerider
07 Apr 2019 19:02
My KZ1000 came with pods and I had a horrible time getting the jetting right for a wide range of operation. I ended up buying a parts bike just for the air box and put it onto my bike. The jetting has been so much easier to dial in and the bike is running great at a wider range of demands.
Keep the box. (My $0.02)
07 Apr 2019 19:21
Buy pods if you want to spend MANY hours fiddling with carbs rather than riding a motorcycle. Personally, I'd much rather ride so I'll always stick with the airbox. Ed
08 Apr 2019 05:57
The 83 550-Ltd should have TK22 carburetors, so check out the motorcycle stuff page by loudhvx >> see links in the signature of any of his replies. He has a ton of info about those carburetors & he may have jetting suggestions for the individual pod filters.
Choke flaps. Be sure to note the page about the choke flaps which can come off. Someone on EB sells reproduction flaps >> you may have to modify them a little, but at least you won't have to start from scratch. There was a somewhat recent topic about the EB flaps, a month or two ago.
- loudhvx
08 Apr 2019 08:31 - 08 Apr 2019 08:32
The TK22 carbs are probably the easiest carbs you'll find on inline-four Kz's for pod jetting. The only simpler bike I can think of is probably the Kz200 single.
The first-gen Kz550's were so lean from the factory, you can actually make it run better than with the factory airbox and stock jets. You can make it start easier and have a lot more pull on the highway. The main reason to stick with the airbox is for weather and not having to do any experimenting or testing.
As Martin mentioned, there is a link in my signature to info you need to know about the valve train, and the other link will lead you to more links about the Tk22 carbs specifically.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 08 Apr 2019 08:32 by loudhvx.
- Calvin9819
11 Apr 2019 21:16
You all do make good points... the biggest problem I’m facing now I even finding a stock airbox that I can use. I’d probably already have swapped it if I could find one! eBay yields 0 results in my latest search
- Oldjeep
12 Apr 2019 08:52
Is this what you need?
Calvin9819 wrote: You all do make good points... the biggest problem I’m facing now I even finding a stock airbox that I can use. I’d probably already have swapped it if I could find one! eBay yields 0 results in my latest search
Chuck
81 KZ750 LTD
03 FZ1
www.oldjeep.com
81 KZ750 LTD
03 FZ1
www.oldjeep.com
- Calvin9819
13 Apr 2019 22:28
That’s From a 1980s model. From what I read they swapped a lot of things over between 80/81 to 82/83. Dude doesn’t accept returns either so if it’s the wrong one I’m stuck with it unfortunately
- davido
14 Apr 2019 00:16
Would an ltd model work? This is advertised for breaking in Holland. 'Luchtfilterbox' is translated as 'air filter box'. Seems to be a business address.
Being Holland, chances are they speak English.
www.marktplaats.nl/a/motoren/onderdelen-...c624&previousPage=lr
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- Calvin9819
14 Apr 2019 06:48
Luckily my aunt is from Belgium and Dutch is her native tongue! Haha. I’ll look into specifically LTD’s because that’s what mine is. Maybe they stayed the same, thank you!
