What port is this? Kz750
- sharkmonkey
04 Apr 2019 08:05
I have been working on an ‘83 KZ750 twin, reconnecting all the open vacuum lines or capping them off. I found this open port between the carbs next to the fuel line input. Where should the line go connected to this?
Thanks.
Thanks.
1983 Kawasaki KZ750 KZ1 LTD (belt)
1980 Honda CM400T
1980 Honda CM400T
- scubaanders
Re: What port is this? Kz750
04 Apr 2019 08:19
That's an over flow tube that is supposed to run out between the frame and the swingarm.
You should have two of them.
/A
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
04 Apr 2019 09:27
Looks like a vent to me.
- gd4now
- Denco where did you go?
04 Apr 2019 11:00
If they are the stock carbs then they are BS 34 carbs and have no overflow system. There are 2 tee ports between the carbs. One of for fuel inlet and the other is for carb bowl venting. This fitting should have a hose connected and run over the swingarm.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- jayrodoh
04 Apr 2019 11:30gd4now wrote: If they are the stock carbs then they are BS 34 carbs and have no overflow system. There are 2 tee ports between the carbs. One of for fuel inlet and the other is for carb bowl venting.
X2. I have sameish bike and same carbs, it is the vent.
1982 KZ750-M1 CSR
- sharkmonkey
04 Apr 2019 12:12
Thank you all!
1980 Honda CM400T
1980 Honda CM400T
04 Apr 2019 12:15
It should go up over the carbs and end on top of the airbox. Less chance for critters making a home in there and no negative air pressure to mess with the floats.
- sharkmonkey
04 Apr 2019 20:26scubaanders wrote: You should have two of them.
/A
I have 2 carbs so I only have 1, correct?
1980 Honda CM400T
1980 Honda CM400T
