Carb Jetting for a removed baffle?
  • WarrensKZ
  • WarrensKZ's Avatar Topic Author
13 Mar 2019 19:16
#800309
On my 77 Kawa I removed the baffle because my sons ride with me and wanted more obnoxious noise.
As a rule of thumb - if there is such a thing - would that require a larger main jet or pilot.?
Stock jetting on my Mikuni VM24s is 102.5 Main, 15 pilot. I was told that I should increase the Main up to sizes to 107.5 to accommodate the removed baffle.
Thoughts on this are appreciated
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Carb Jetting for a removed baffle?
13 Mar 2019 20:24
#800312
You'll lose power in the top end.
  • kevski
  • kevski's Avatar
14 Mar 2019 01:48
#800318
There is no magic formula, but you need to go up on both circuits at least one size, and then up in increments of one at a time on each circuit separately until you get there, also you may have to raise or lower or even shim the jet needless, everything else such as valve lash, ignition timing, cam chain adjustment need to be correct also, all this needs to be done if you are going to do the job properly.
  • Warren3200gt
  • Warren3200gt's Avatar
  • Away
14 Mar 2019 03:01
#800320
Kevski is right, no magic formula but a dyno will take some of the trial and error out of it.
PS you have mail Kev.
Z1000J2 somewhat modified!
  • KZB2 650
  • KZB2 650's Avatar
14 Mar 2019 15:07 - 14 Mar 2019 15:09
#800353
Thinking it would defently be too lean with the jets you have and mine with different carbs 24s and 29mm smooth bores and playing with the jetting never seemed to run quite as good as with the baffle in. Too Easy to piss off the cops and folks in your area too.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 14 Mar 2019 15:09 by KZB2 650.
