Kz1000 carb on 650
- Blue58
- Old, Bald and Fast
Kz1000 card ơn 650
15 Feb 2019 07:48 - 15 Feb 2019 08:16
I have a sét of carbs off a 1000 of unknown year. My questions are
These need vacume to run my current setup is not, What do i need to do and is this possable? And would this be an upgrade over stock?
Last edit: 15 Feb 2019 08:16 by Blue58. Reason: misspelling
Re: Kz1000 card ơn 650
15 Feb 2019 08:12
The carburetor spacing is probably different. I don't know what you mean about the vacuum question, unless you're referencing the fuel petcock.
- Blue58
15 Feb 2019 08:14 - 15 Feb 2019 08:18
Well yes I have a gravity feed at the moment. Can I just block off the vacuum ports on the larger carbs? or just replace my petcock with a vacuum one?
Last edit: 15 Feb 2019 08:18 by Blue58.
15 Feb 2019 08:20
You can block the vacuum ports. Use good automotive vacuum caps.
Have you checked the spacing? I think it'll be different.
15 Feb 2019 08:28
Can you provide photos of the carbs to that we can identify them?
KZ 1000 carbs from 1973 to 1980 didn't use vacuum ports. Depending on the model there may be as many as three but usually two air vents. These should not be blocked as they provide the differential air pressure for carbs to work properly.
If your carbs are newer than 1980 they may have used a vacuum petcock but I have no experience with anything newer.
- Blue58
15 Feb 2019 08:32 - 15 Feb 2019 08:32
I cant at this moment get a picture . I am in Fla. the Carbs are in NH PS Sorry about the typo in the header
Last edit: 15 Feb 2019 08:32 by Blue58.
- kevski
15 Feb 2019 12:01hardrockminer wrote: Can you provide photos of the carbs to that we can identify them?
KZ1000 A2 had 26mm with a vacuum port for the petcock, and other models with 28's and CV's did also.
15 Feb 2019 12:48kevski wrote: KZ1000 A2 had 26mm with a vacuum port for the petcock, and other models with 28's and CV's did also.
You're right!...for the A2. Not sure on A3 or A4 because there's no fiche for them. All of the B series B1 to B4 had gravity feed.
15 Feb 2019 14:46
All the carbs are gravity feed. The carb vacuum port is to drive the petcock on/off function.
- seanbarney41
- '79 kz1000 LTD '75 Honda CB750
15 Feb 2019 15:16
The spacing is fine. I have vm28ss on my kz650. However, you may need carb holders from a kz1000, I can't remember.
- baldy110
15 Feb 2019 18:29 - 15 Feb 2019 18:30
Need to swap manifolds to the 1000 ones, and if the set of carbs you have doesn't have the vacuum port then swap in a manual petcock on the tank. The spacing is the same. They will require some tuning but will work, you'll lose some low end torque but gain mid and upper.
Last edit: 15 Feb 2019 18:30 by baldy110.
- Blue58
16 Feb 2019 05:39 - 16 Feb 2019 05:40
Thanks for the information. I know I need kz 1000 intake boots to make it work. Adding a vacuum petcock should be easy. Once home I will take pictures and update this thread.
Last edit: 16 Feb 2019 05:40 by Blue58.
