Carb boots
  • Quigleyje
  • Quigleyje's Avatar Topic Author
Carb boots
17 Nov 2018 10:57
#793868
I'm changing the engine in my 81 kz550 to an 84 zx550
But the carb boots are different. I'd like to keep the carbs from the 81. I think carb boots from a 1977 kz900 will work but not sure hoping someone will have the answer.
81/84 kz/zx550
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Carb boots
17 Nov 2018 11:20
#793870
Measurements? I have one to compare to.
  • Quigleyje
Re: Carb boots
17 Nov 2018 13:47
#793875
73mm base 29mm inlet for the carb
81/84 kz/zx550
  • hardrockminer
  • hardrockminer's Avatar
  • Away
Re: Carb boots
17 Nov 2018 15:39
#793877
Z1 & KZ900/1000 from 1973 up to at least 1980 use the same intake boots.
I measure one carb boot installed on the manifold at 1-11/16 in. OD where the carb fits into the boot. The distance from the outside of #1 to the outside of #4 is 11-3/8 in. That's the distance between the outer edges of the boots when installed on the head.
