instantly starts, holds idle for while, starts dying, can't recover with throttl
  • mnrenfro
  • mnrenfro's Avatar Topic Author
03 Sep 2018 07:45
#790216
I've never been this snakebit on a bike. It will start just fine, holds idle for a minute or two, then starts to die down, and can't even be kept running when I twist the throttle. I tried sticking my finger in the intake of one carb and lifting the needle and it responds positively to that. I have tried rebuilding the carbs, replacing all the gaskets (some more than once), the boots between the head and carbs are in tact. I'm at a loss.
Any helpful information is much appreciated.
  • hardrockminer
  • hardrockminer's Avatar
Re: instantly starts, holds idle for while, starts dying, can't recover with throttl
03 Sep 2018 14:55
#790249
How is your fuel flow to the carbs?
  • mnrenfro
03 Sep 2018 17:47
#790269
well when I loosen the drain screws the gas flows pretty well, so I suppose it's good..??
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Sep 2018 18:07
#790274
Are the coils getting too hot?
  • hardrockminer
03 Sep 2018 19:31
#790284
mnrenfro wrote: well when I loosen the drain screws the gas flows pretty well, so I suppose it's good..??
You may only be getting fuel from the bowls. Try taking your hose off at the carburetor and check flow with the petcock full open.
  • mnrenfro
03 Sep 2018 20:00
#790287
that I don't know. Was that a problem on the KZ400 model?
  • mnrenfro
03 Sep 2018 20:01
#790288
thanks I'll try that.
  • hardrockminer
03 Sep 2018 21:04
#790293
The reason I suggested it was because it sounds like the bike is starving for fuel...just like when the petcock is shut off while the engine is still running.
  • Warren3200gt
  • Warren3200gt's Avatar
04 Sep 2018 00:03
#790297
Fuel cap breather hole blocked?
Z1000J2 somewhat modified!
  • baldy110
  • baldy110's Avatar
04 Sep 2018 18:44
#790344
I bet it will only run with the choke on?
