KZ400 VM32 Conversion
  • Fischer779
  • Fischer779's Avatar Topic Author
  • My bike runs on the tears of bald eagles
21 Jul 2018 18:59
#787365
I've been fighting this for several months now and decided to pass it on to the experts.
Problem: The bike idles at 3500-4000 rpm. I've tracked it to one of the carbs, when I switch the carb from side to side the high idle follows it. The boots are new, the ignition system is new, the engine was just rebuilt and ALL seals are new. The carbs were boiled in lemon juice/vinegar after careful hand cleaning (there is 0 dirt in them), this made it run better but didn't solve the idle problem. All the carb gaskets are fresh and all the jets/needles are new but the carbs themselves are second hand. I have sprayed everything with pb blaster to check for air leaks and couldn't find any. Pulls almost as hard as my yz400f and there aren't any holes so I'm pretty happy with the jetting, only issue is the idle. Is there anything i can look for on the bad carb that may be causing this?
Any info would be a huge help, i really just want to ride it.
Thanks.
Bike info:
-75 KZ 400
-ported cylinder head,
-head milled for compression (10.5 ish),
-2 into 1 "open header" (loud as hell)
-Uni foam pods
-Dual Mikuni VM 32 carbs
-25 pilot
-210 main
-6f5 needle
-clip position?
        -2.5 slide
YZ400f "dual sport"
KZ400D
95' Corvette
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: KZ400 VM32 Conversion
21 Jul 2018 19:27
#787369
1] carbs are to big
2] they are jetted like a 2 stroke
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: Fischer779
  • Fischer779
21 Jul 2018 20:11
#787371
1.] Yes the carbs are big...maybe too big. This was done intentionally to support the ported head/exhaust and a web camshaft in the future. Research suggests there are other people running these carbs on less modified engines with success, that doesn't mean its correct its just a data point. Given that the bike feels like its going to wheelie when i get on it, this leds me to believe the sizing isn't too far off. the bike might be even better with small carbs though.
2.] Jetting is similar to all other kz400/440s running vm32s not sure why they like the mains so big but they do. The plugs look great. There is power everywhere, even cruising around under load at a 'normal' idle speed.
Let me restate my problem. ONLY ONE CYLINDER is running high at idle. This is caused by ONE of the two carbs because when i switch the carbs around the problem follows the 'bad carb'. When I progressively apply the choke to the 'bad carb' the idle returns to a normal 1000-1500 rpm but the cylinder starts misfiring and coughing on the fuel. I was thinking there might be a crack or some other defect on the carb. Thanks for the replies.
YZ400f "dual sport"
KZ400D
95' Corvette
  • Nebr_Rex
  • Nebr_Rex's Avatar
22 Jul 2018 06:33
#787386
Your idle circuit is lean on that carb.
The reason the jetting is so big is because the ventri effect/signal is weak. The air velocity thru a big carb feeding a small displacement cylinder will be lazy. A larger jet will be needed to 'pull' the fuel required. On a 2 stroke there is less time to get the air and fuel into the cylinder. 2 stroke carbs have larger needle jets to accomplish this. A big 2 stroke carb on a small 4 stroke is going to need large jets.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • TexasKZ
  • TexasKZ's Avatar
22 Jul 2018 11:54
#787407
Have the carbs been properly synchronized? Fuel levels checked?
  • Nessism
  • Nessism's Avatar
  • Online
22 Jul 2018 12:11
#787408
Bike needs some mufflers too.  Too much flow on both sides of the engine.
  • Fischer779
22 Jul 2018 13:04
#787422
I set the float level with a caliper to insure both carbs were the same. The tangs are parallel with the bowl gasket. The carbs were synced with a drill bit, I don't remember seeing any vacuum ports on the head. I have plans to make some through the carb bodies or boots once I have access to a machine shop again.
I don't see any reason to put a muffler on at this time although I'd eventually like to buy something nicer, right now Hagon shocks are higher up on the list. The primary tubes are the same diameter as stock and similar in length to the commercial 2 into 1 systems so I doubt the scavenging is messed up. I also don't see how that could cause one cylinder to idle fast while the other is fine.
I plan on experimenting with a 27.5 pilot on that side.
YZ400f "dual sport"
KZ400D
95' Corvette
  • TexasKZ
  • TexasKZ's Avatar
22 Jul 2018 15:00
#787435
Setting the float height is a good preliminary step, but the actual fuel level should be confirmed via the clear tube method.
Likewise, setting the slide openings on the bench is a good start, but they should be fine tuned with vacuum guages, or other appropriate tool. Don't the VM carbs have a vacuum port? Maybe I am old and forgetful, but I thought they each have a fuel inlet, a bowl vent and a vacuum port.
Are you certain that both throttle cables are releasing properly? Perhaps one is hanging up.
  • TexasKZ
  • TexasKZ's Avatar
22 Jul 2018 15:07
#787437
So you are going to change the pilot in one carb? They should be the same unless something is seriously screwed up.
  • Nessism
  • Nessism's Avatar
  • Online
22 Jul 2018 15:15
#787438
Agree.  Do not bump pilot on one side.  The jet size is not the problem.  You most likely have an air leak, and spraying stuff on the carbs doesn't always find vacuum leaks.
  • loudhvx
  • loudhvx's Avatar
22 Jul 2018 16:07 - 22 Jul 2018 16:09
#787447
Are they real Mikuni, or Chinese knockoffs?  You might simply have a defective carb with a crack somewhere or a leak from a casting void.
My buddy ordered a Weber performance carb for his son's Toyota Celica, but he couldn't get it to idle right.  When he brought it to me to checkout, I found an 1/8th inch hole in the sidewall of the carb leading straight into the throat.  It was a casting flaw.  When he called the supplier, the supplier seemed to be aware of the problem and sent him a new one.  The funny thing is, the supplier and I both agreed that it should not have affected the idle since it was above the throttle plate.  But if there is that major of a flaw in the body, who knows what other flaws there might be.  They sent him an upgrade carb at no additional cost, and that one seemed to run great out of the box.
Last edit: 22 Jul 2018 16:09 by loudhvx.
  • Fischer779
24 Jul 2018 17:34 - 24 Jul 2018 17:35
#787605
The carbs are real but they are second hand, likely off an old 2 stroke snowmobile. I went over them thoroughly and didn't see any cracks but its possible I missed one. They are completely clean with new gaskets and brass (besides the air jets although they were the same). Any suggestions for finding an air leak besides spraying crap on the carbs? Only thing I can think of is getting a cigar and blowing smoke near the carbs.
I have 27.5 pilots on order. I plan on trying both of them first and if it causes fueling issues in the good cylinder I will try a combination of the 25 and 27.5. I'm not real worried about running 2 different pilots. Its possible my carbs were manufactured at different times and the tooling could have been different although they look identical.
Thanks
YZ400f "dual sport"
KZ400D
95' Corvette
Last edit: 24 Jul 2018 17:35 by Fischer779.
