34 or 36 RS ?
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
34 or 36 RS ?
16 Jun 2018 04:07
#785241
My engine off my 77' KZ1000 is in the process of being rebuilt ( Wiseco 1075 and head port ). Been tossing around the idea of taking it to another level by upgrading to Cams ( K410 ) and bigger carbs. Looking at Mikuni RS34 or 36's . Wanting to build a Good Street motor with great bottom end to mid-range, which is where the motor will be ran most of time.
Opinions on what Size RS's ?
77' KZ1000A
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
Re: 34 or 36 RS ?
16 Jun 2018 10:08
#785256
I built my 1075 with stock cams for reliability and versatile range vm 26s just wasn't enough and the 34s really woke up the action. These are old bikes {Dinosaurs} So I went to suspension improvements as much as my wallet would allow my Girl friend to let me. You cant eat motorcycle parts and there will always always going to be a faster more agile high tec bikes to blow mine away. Its the nature of the beast. So I did upgrades and am more than happy for now,,, I do have the head milled incase I want to go with more radicle cams though. As is My 900 will trounce my 78 1000 Ltd any day of the week. Maybe my age keeps me modest
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: 34 or 36 RS ?
16 Jun 2018 11:06
#785266
kzdcw wrote: My engine off my 77' KZ1000 is in the process of being rebuilt ( Wiseco 1075 and head port ). Been tossing around the idea of taking it to another level by upgrading to Cams ( K410 ) and bigger carbs. Looking at Mikuni RS34 or 36's . Wanting to build a Good Street motor with great bottom end to mid-range, which is where the motor will be ran most of time.
Try vm28s,29 smooth bores or BS34s. RS34s would be to big.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • DFIGPZ
  • DFIGPZ's Avatar
Re: 34 or 36 RS ?
16 Jun 2018 11:37
#785268
I would run the 36mm Flat Slides
1984 750 Turbo
  • DoctoRot
  • DoctoRot's Avatar
Re: 34 or 36 RS ?
16 Jun 2018 12:08 - 16 Jun 2018 12:09
#785269
I'm running 1075, street port and polish, and mild cams with RS 34. They may be a bit too big but this engine rips
I figure if Rs34 carbs are intended for race only kz750s they are fine for a street 1000
Last edit: 16 Jun 2018 12:09 by DoctoRot.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 34 or 36 RS ?
16 Jun 2018 15:23
#785278
RS34 is the maximum you have to go for, RS 36 only if your cubic capacity is 1200-1300 ccm.
You will loose power on lower rev and torque without a ported head and bigger valves/valve lift/cams.
  • kzdcw
  • 77' KZ1000A
Re: 34 or 36 RS ?
16 Jun 2018 15:55
#785280
My cylinder head will be ported and flowed with slightly oversized valves. I'm tossing the idea whether to keep the "stock" cam or go with the K410.
So RS34's without cam and RS36's with cam upgrade ?
77' KZ1000A
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 34 or 36 RS ?
16 Jun 2018 16:00 - 16 Jun 2018 16:03
#785282
You will loose power and torque on lower rev without a ported head and bigger valves/valve lift/cams. In other words, big carbs = un-drivable bike = no fun.
You need a minimum of air velocity in the carb/intake ports (optimum 90-100 m/sec.) for a good performing engine! A bigger carb is suboptimal if any other engine parts are not fit to your carb setup, from inlet to outlet. In other words you have to go with the right carb with your engine environment.
Use the RS 34 if no 1200 ccm or more is projected in the near future.
Last edit: 16 Jun 2018 16:03 by Scirocco.
  • kzdcw
  • 77' KZ1000A
Re: 34 or 36 RS ?
16 Jun 2018 16:04
#785285
So just to make sure I understand, RS 34's in my application whether I stay with the stock cam or upgrade to the 410 ?
77' KZ1000A
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 34 or 36 RS ?
16 Jun 2018 16:08 - 16 Jun 2018 16:14
#785286
Yes, the RS34 is a good starting point, everything else would be a waste of money.
Step by step is the progress.
www.mikuni-topham.de/ENGLISHSITE/ENGLISH/Frame_English.html
www.mikuni-topham.de/ENGLISHSITE/Carbure...h/Kawasaki_main.html
Last edit: 16 Jun 2018 16:14 by Scirocco.
  • DFIGPZ
  • DFIGPZ's Avatar
Re: 34 or 36 RS ?
17 Jun 2018 10:19
#785319
36mm with ported head and cams fine do not buy into carb to big flat slides have a super good signal to them I have many 1075 running them.
1984 750 Turbo
  • kzdcw
  • 77' KZ1000A
Re: 34 or 36 RS ?
17 Jun 2018 16:44
#785343
I respect and appreciate Both of your opinions. I lean towards the RS34's only because I want the most low-end and mid-range performance increase and will never run anything bigger than the 1075 displacement. My engine builder say go with 36's but still not decided ?
77' KZ1000A
