CVK32's for my 550
- Wozza
CVK32's for my 550
07 Jun 2018 00:27 - 07 Jun 2018 06:21
The engine will be 615cc, would my best bet be to order a zx600 cvk32 needle and jet kit from factory pro
I believed the cvk carbs i thought where gpz600 are actually from a 1988-89 Australian zx900r, according to the needles and jets in them .
Using a set of ZR550 carb boots i have successfully fitted them to my 1982 GPZ550 h1 with factory airbox.
1982 KZ550H1
Last edit: 07 Jun 2018 06:21 by Wozza.
- wiredgeorge
Re: CVK32's for my 550
08 Jun 2018 08:31
Take a pic of the carbs fitted on the bike. Curious to see this. As for jetting, I would just stay away from jet kits as they will only compound set confusion. Best to see how the bike runs as is first before modifying the jetting.
- Wozza
08 Jun 2018 15:13 - 08 Jun 2018 16:07
i set up my spare empty cases, block and head in the frame and test fitted the carbs. I am still waiting on parts for the actual engine i will be using
I wasn't expecting the air box to fit but there it is,
They also use a single pull cable instead of the push/pull arrangement on the 600's
1982 KZ550H1
Last edit: 08 Jun 2018 16:07 by Wozza.
- CoreyClough
- GPz550 Addiction
09 Jun 2018 08:01
I have been running the CV32 from a ZX600C for years, and using the ZR550 Intake Holders. You will need to belnd the ID of the intake holders on the carb side, as the ID of the ZR's CV30 Carbs are smaller than the CV32. Outside diameter of CV30 and CV32 are the same and carb spacing is the same on these carbs. Both use the same throttle cables, so either ZR or ZX600C throttle assembly will work. I had Motion Pro make me a custom Rev2 Throttle Kit. Love it!
Current engine is K&N Pods, and all else ZX550 with 4-1 Exhaust. Cam timing is stock ZX550 Exhaust and KZ550 Intake, using ZX550 Cams.
'85 GPz550(ZX550-A2)
The following user(s) said Thank You: Wozza
- CoreyClough
- GPz550 Addiction
09 Jun 2018 15:30 - 09 Jun 2018 15:53
I read your post too fast, and just now caught that you have CV34 Carbs from a 900. You'd be the first I know if you wanted to tune them to your H Model with Air Box. I'd suggest usnig the ZX600 and I have used Dynojet Kits with good results in the past. Because I am running Pod Filters, your jetting with the air box will be different.
I'd recommend buying a wide band and tune for road use. I've posted this before but here is what I have yet to install. A good friend of mine has been using his Wide Band to tune his CV32 Carbs to his 12:1 615cc and Web Cam Engine. He is such a good friend, that he will not help me with additional jetting questions on my set up, till I have the LC1 installed. He says using it will answer most of my questions. LOL!!!
www.innovatemotorsports.com/products/db.php
In this picture, I am using the needles on the right with shims added. Tomorrow I will have the carbs off, and will list my current settings.
Last edit: 09 Jun 2018 15:53 by CoreyClough.
- Wozza
09 Jun 2018 15:59 - 09 Jun 2018 16:02
Hi Corey. Awsome Its because of you that i knew about this carb swap . Thanks
These are CV32 ZX900 carbs, check out the attachment in my first post, australian 900's got the 32s.
i thought i was getting a 600 set. clues are black paint, single pull cable. jets, needles
I just cant see that 90 main being any good for power, but maybe im wrong
I think my engine specs are going to be similar to yours other than the K&N Pods. Maybe down the track, but for now its going to be a modified airbox with UNI filters.
1982 KZ550H1
Last edit: 09 Jun 2018 16:02 by Wozza.
The following user(s) said Thank You: CoreyClough
- Wozza
09 Jun 2018 16:16 - 09 Jun 2018 20:08That interesting i didn't realize your using ZX600 needles. for some reason i though you had aftermarket needles .In this picture, I am using the needles on the right with shims added. Tomorrow I will have the carbs off, and will list my current settings.
the N27C needles look more like the N27L than those pointy 52Q's your using
yes wide band is in my future for sure , One of the guys i work with circuit races and uses a AEM to help dial in the carburettor on his racecar and swears by it.
1982 KZ550H1
Last edit: 09 Jun 2018 20:08 by Wozza.
- CoreyClough
- GPz550 Addiction
10 Jun 2018 06:41 - 10 Jun 2018 06:43
I was always using the jet kit, then Gary started using the wideband, and found information about the shape of the needles. He went back to the pointy needle, and for street/backroad riding, those were the ones to use. All out racing will need different settings, but to tune the carbs to the engine for the street, or constant cruise is what we set for me. Doing a throttle chop then reading spark plugs is no way as accurate as getting real time readings. he is running a modified ZR550 Stock Exhaust with an aftermarket silencer. Here is his set-up when tuning only, as he removes the system and sensor after tuning is complete:
Last edit: 10 Jun 2018 06:43 by CoreyClough.
- CoreyClough
- GPz550 Addiction
10 Jun 2018 16:29 - 10 Jun 2018 16:30
Here is my CV32 Jetting:
135 Factory Pro mains (Same as Dynojet 124)
38 Pilot
1.25 turns out mixture screws
N52Q Needles with 0.092" Shim Stack
17mm Float Height
38 Pilot
17mm Float Height
Last edit: 10 Jun 2018 16:30 by CoreyClough.
- Wozza
05 Sep 2018 04:13 - 05 Sep 2018 08:28
now that i have sorted the clutch i can get the carbs ready for tuning. so i have bought
o rings for the fuel and vent tubes
zx600 factory pro jet needle kit i found for half price
keyster gasket float valve kits
i think that should cover it other than a few more sets of mains
the engine has kz550 timed zx550a cams.
10.5:1 comression
4-1 exhaust
Modified stock airbox uni filters
I have also welded an O2 sensor bung onto the exhaust so i can use a LM2 to dial it all in.
Before I order some more mains should I also add some 38 pilots to the list. I see Cory is using 38's but the pilot airjets on his cvk32's are larger than my set or should I just wait and see how many turns the pilot screws end up needing.
old and new needles
10.5:1 comression
4-1 exhaust
old and new needles
1982 KZ550H1
Last edit: 05 Sep 2018 08:28 by Wozza.
- CoreyClough
- GPz550 Addiction
06 Sep 2018 05:11 - 06 Sep 2018 05:17
Following this one.
You can use the standard 35 pilots, but having a set of next size up 38's might be needed if the readings deem necessary. I haven't used the Factory Pro Jets.
What is stamped on the needles you are showing on the right above? N27L???
I have found a difference in the CV32 Carb from the 1985-1992 ZX600C Era. The butterflies are shown in the two below, noting the little pin hole and lack of one in the other. Also there are not any air holes in the throat of the lower opening, also visible.
Last edit: 06 Sep 2018 05:17 by CoreyClough.
- Wozza
07 Sep 2018 02:00 - 07 Sep 2018 04:19
ok thanks Corey. I think i will get some just in case, i cant find anyone over here who sells new jets just used ones so i need to order them from over east or USA
The Factory pro needles are 0964g-76p-40t.2 for richer at 5000 to 7000 the recommend getting 0964g-72p-40t.2 needles
Think I going to bench set them to
110 factory pro main jet - not sure what the equates too
Factory pro needle - clip in middle groove third from the top
35 pilot jet- what's in it already
Pilot screw 2 turns out - std.
these 32's dont have holes in the butterflys and all look identical with 3 bleed holes.
edit. using phone so photo is not the best
1982 KZ550H1
Last edit: 07 Sep 2018 04:19 by Wozza.
