26mm carb question
  • Ronnie_D
  • Ronnie_D's Avatar Topic Author
  • 1978 KZ1000 A2
26mm carb question
07 May 2018 19:54 - 07 May 2018 19:54
#783043
Hello Guys,
I am restoring a 78 KZ1000 A2. I have cleaned the carbs and all looks good. I am wondering what the outer 2 circled ports are for. The middle one with the hose came off the vacuum petcock side. What should I do with the 2 open ports?
thanks,
Ron.
Last edit: 07 May 2018 19:54 by Ronnie_D.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 26mm carb question
07 May 2018 20:05
#783045
Those are vents. Not sure of the center one.
07 May 2018 20:16
#783047
The following user(s) said Thank You: Ronnie_D
  • Ronnie_D
  • 1978 KZ1000 A2
07 May 2018 20:26
#783051
Thank you Ed.
I will run some hose down off them.
cheers,
Ron.
