First start running rich/backfiring
  • Crusdm90
  • Crusdm90's Avatar Topic Author
26 Apr 2018 20:49 - 26 Apr 2018 20:50
#782459
I have just reinstalled my carbs after a thorough cleaning. I am now backfiring at idle on cylinder 1 or 2 not sure and exhaust fumes smell of large amounts of fuel. I'm curious if anyone can suggest if I should be looking at fuel screws which is set to how they were stock or ignition
Etc.? I have slip on mufflers which were not on originally if that makes a large difference at idle I suppose not.
Last edit: 26 Apr 2018 20:50 by Crusdm90. Reason: Typo
  • TexasKZ
  • TexasKZ's Avatar
Re: First start running rich/backfiring
26 Apr 2018 21:18
#782462
Did you check the fuel level in each carb using the clear tube method?
Did two of the sparkplug wires get installed on the wrong spakplugs?
The following user(s) said Thank You: Crusdm90
  • Crusdm90
26 Apr 2018 21:57
#782464
I have done the clear tube method multiple times and i found that I had cracked over flows. I went ahead and soldered the over flows and set the bowl heights to spec. I Will double check spark plug wires also but I'm certain it may be something else. How often do the ignition systems fail on these bikes I have read a few things on here that suggest it's common but this bike only has 7000 miles on it of course it's a 1980 so age is its biggest enemy. Is there anything else I can check to gather more info? Spark plug's 1 and 2 were black and smeled of gas.
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Apr 2018 13:36
#782505
Disconnect the plug wires and look for green crap on the ends. If so nip 1/4" off the ends and put them back on.
