- Thank you received: 2
When to Jet up
- gregoryzim
22 Apr 2018 00:13 #782149
by gregoryzim
When to Jet up was created by gregoryzim
It seems to be well recognised that the area that causes the most trouble to owners is carburetors.
Well if thats half true it certainly is the case in my case of the KZ1100.
So - I've done everything possible to get perfect proper running with correct colour plugs - balanced, re-kitted, tried every combination setting possible with the fuel/air mixture screws on each carb, set the float tab levels, put a standard air filter back on etc etc.
Best performance (pulling strongly on all stages of acceleration I can get with minimal popping is a fuel/air setting that always shows the plugs a black, but it certainly isn't perfect (in terms of the popping (still pops consistently on cruise - only stops if going full blast
Now here's the thing - the bike is running an after market muffler/silencer and there I am guessing is the issue. (cant get original anywhere I can see)
Its got all original jets - so now I feel I need to up the main jet? Friends have said only the main jet needs changing - to 140 (current standard is 120R (whatever the R stands for??)
Now I discover I have a jet kit but the mains are only 125 - Doesn't sound like much of a change - but I don't know - no experience in difference between jet sizing.
If anyone has been through this process and has any thoughts - before I pull the carbs out "again" , please let me have your thoughts.
- Thank you received: 2829
22 Apr 2018 05:19 #782155
by 650ed
Replied by 650ed on topic When to Jet up
On stock engines the two carb issues I have read the most about is leaking carb holders (which is easy to detect) and removing the stock air cleaner. If you have installed pods or some other non-stock air cleaners rejetting can be a very big challenge because it changes the dynamics of how the carbs breathe - not just how they are filtered. If your carb holders are leaking the problem will show up mostly at idle speed and can be tested and corrected if necessary. Ed
The following user(s) said Thank You: gregoryzim
- Thank you received: 2098
22 Apr 2018 06:47 - 22 Apr 2018 06:47 #782163
by Patton
Replied by Patton on topic When to Jet up
Stock carbs likely worked just fine when the bike was new.
Would suspect carb pilot circuits aren't perfectly clean, including the orifices feeding into the bore.
Last edit: 22 Apr 2018 06:47 by Patton.
- Thank you received: 2754
22 Apr 2018 07:24 #782165
by SWest
Replied by SWest on topic When to Jet up
Valves adjusted?
- ajsfirehawk
- Thank you received: 89
22 Apr 2018 09:51 #782170
by ajsfirehawk
79 KZ650 SR
80 KZ1000 Z1 Classic
83 KZ1100 LTD
Z900RS
23 Mach 1
Replied by ajsfirehawk on topic When to Jet up
Gregory, take a quick look at the number of posts for the Gents that just gave you suggestions. They all represent good advice. With the engine warmed up and idling, shoot a short blast of starting fluid on the carb holders/carb connection. If the RPMs rise, you have a leak. As Ed said, easy. Careful where you shoot that stuff as it is ridiculously flammable.
Patton has a diagram of the carb circuits I suspect he would share if you are committed to verifying the circuits are clean. Once those two things are one of the best ways to set the idle circuit AFR is a Colortune plug. You can actually see the combustion in the cylinder. It costs $75.
www.amazon.com/Colortune-for-14mm-Spark-...colortune+spark+plug
If you don't know where the valves are set, you should establish where they are and address any out of spec issues. In part for this issue you are working but also for the health of your motorcycle. If the valves aren't closing fully it is going to honk up the vacuum to the carbs which directly affects their performance. Plus you are going to burn a valve. Just to verify, are we talking about BS34 carbs here?
79 KZ650 SR
83 KZ1100 LTD
Z900RS
23 Mach 1
22 Apr 2018 10:28 #782173
by SWest
The valves are commonly ignored. Po's say the carbs need cleaning when they were too lazy or cheap to adjust them. Basics first then go to the carbs.
- gregoryzim
27 Apr 2018 02:37 #782473
by gregoryzim
Replied by gregoryzim on topic When to Jet up
Thanks for the input Guys. Along the journey there was a split boot and leak but no leaks now. The carbs are completely clean and new jets. When I bought the bike (before restoring) there were pods but now just good old original airbox.
The one thing not checked from your combined list is the valves. If anyone knows of a good article, info or video that you can recommend I start to learn through please let me know thanks. Rgds Greg
- Thank you received: 2236
27 Apr 2018 05:07 #782475
by TexasKZ
Replied by TexasKZ on topic When to Jet up
The factory service manual explains the procedure for checking and adjusting the valve clearance pretty thoroughly. There are even pictures and a chart.
- 2wheeladdict
- Thank you received: 3
28 Apr 2018 05:13 #782518
by 2wheeladdict
80 KZ1000 LTD
81 Yamaha XJ650 maxim
84 CR60r
Replied by 2wheeladdict on topic When to Jet up
I had almost the same symptoms as your having. I had freshly cleaned /rebuilt carbs brand new holders and boots and still had the issue. I took my bike to a local vintage bike shop and the valves were the culprit. I have the spec sheet somewhere that he documented the clearance( or lack of) and what shims he used to get the proper clearance. They were off quite a bit. Sounds like this might be your next thing to check.
80 KZ1000 LTD
84 CR60r
