Needle jet springs
- Bigz
Needle jet springs
17 Apr 2018 08:25
I'm going through the carbs on a 1979 kz650sr D2. I've gotten to the needle jets and I'm not seeing any springs between the needle clip and the piston. Is this something common for this year and model of bike or am I following the work of someone who hacked a carb job?
Re: Needle jet springs
17 Apr 2018 16:40
- Bigz
17 Apr 2018 19:45
Yes, that's the spring I see is "supposed" to be there. There isn't one of those springs on any of the needle jets. The carb rebuild kits that I bought didn't come with any springs that could fit in the 1/16" space that the needle has to travel.
18 Apr 2018 05:23
Partzilla lists them as in stock and only $2.39 each !
Looks like they fit a wide variety of models, so you may be able to score some used ones someplace.
- Bigz
18 Apr 2018 06:44
Ok. So does that mean I'm not crazy and it does in fact need those springs, and I didn't just get some odd year with a carb that doesn't need them? I just thought it exceptionally odd that not one of the carbs had the spring.
18 Apr 2018 07:39
Pics of what you have?
- ajsfirehawk
18 Apr 2018 09:30
Note the washer, #47. It needs to be in there as well.
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
83 KZ1100 LTD
18 Z900RS
23 Mach 1
- Bigz
18 Apr 2018 09:59
This is it. None of the needles came with springs. The guy said it was running before I took it apart to clean.
18 Apr 2018 10:50
A washer would keep the needles from moving. I guess the springs would keep them more solid. Never seen them before.
- gd4now
- Denco where did you go?
18 Apr 2018 11:18
Not all of the vm24ss or vm22ss carbs that were stock on the KZ650 made use of the springs. It is my understanding that the carbs that came with needles that only have one slot (non adjustable ones) did not make use of the springs.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: Bigz
- zed1015
18 Apr 2018 12:43
Your carbs do NOT need springs.
18 Apr 2018 13:13
See link below for diagram of 1979 KZ650-D2 carbs. Ed
www.partzilla.com/catalog/kawasaki/motor...-d2/carburetor-parts
